blackbox file
DNguy4
I have a VHDL blackbox file my_file_bb.vhd in which I declare all the input and output ports.
When I instantiate it from another program ... entity TEST: my_file port map.... Quartus keeps complaining that object my_file is used but not declared. I thought the blackbox file already takes care of all the declarations. Do I need to do anything else to use the blackbox file?
Vicky1
Have you done the declaration of component for my_file_bb.vhd in TEST ?
Please refer the below video for the reference & try at your end,
https://www.youtube.com/watch?v=JUVDRNeywI8
Vicky
Vicky1
May I know any update or should I consider that case to be closed?
Vicky
DNguy4
yes, it's closed. Sorry that i cannot log in for a long time.
sstrell
Can you post your code for the black box file and the instantiation? That would help to analyze this.
#iwork4intel
Abe
Valued Contributor II
The issue here is you've used the VHDL black box module without declaring it. Before you use the BB module in your VHDL Architecture block via a Port Map, you have to declare the BB module as a Component. All you need to do is to add a component declaration for the black box module under the Architecture block and then use it in the Port Map.
Architecture RTL of XXX Is
Component my_file Is
Port (
end component;
Begin
Port Map ( );
It should resolve the issue. Else post back with your code and we'll help you resolve it.
DNguy4
It's working now. I forgot to declare it as a component.
