17253 Discussions
convolution in Quartus
hello again
does quartus have any special function or module for calculating discrete-time convolution?
Yes, FIR compiler.
FIR = running convolution of input stream with coefficients.
i.e. it applies convolution to the continuous stream of input
you mean FIR compiler that is in the Mega plug-in manager or something else?
Yes Altera's FIR compiler, where-ever they have put it.
You will set it as a filter with cutoff, coefficients etc then the module will convolve its input with coefficients.
