17255 Discussions
cyclone II differential IO error
I have an LVDS transmitter and LVDS receiver in my design and i am getting below error when i do systhesis.
"Input port DIFFERENTIALIN can only connect to output port DIFFERENTIALOUT of another IO atom"
I have also attached the file in which it is giving this error.
--- Quote Start ---
--- Quote End ---
Goto Assigment -> Pin planner. Select that you signal is LVDS. Connect positive and negative signals to pins.
The solution you suggested does not work, still i am getting sythesis error.
ARTEM,
one more thing when i chane the device to cyclone III and do sythesis then it does not give any error even if i do not assign pin for LVDS signals.
Is it some issue with ALTLVDS of cyclone ii?
regards,
