17253 Discussions
duplicate a component
I am having a problem with component duplication.
I would like to duplicate this 2 port maps in one command (loop,generate...)
I have 2 types of parametes that need an Index:
1.1bit from an std_logic_vector m0_piezo_lg_p(0)
2.a regular register (m0_hifu_hv_pw0).
Can somebody assist?
Many thanks
M0_pulser_block0: pulser
port map
clk_64m => clk_64m,
reset_n => reset_n,
piezo_p => m0_piezo_lg_p(0),
piezo_n => m0_piezo_lg_n(0),
fire_busy => m0_fire_busy(0),
fire_piezo_1clk_r => fire_piezo_1clk_r,
fire_piezo_1clk_f => fire_piezo_1clk_f,
hifu_cal_sel => hifu_cal_sel,
hifu_hv_pw => m0_hifu_hv_pw0,
cal_hv_pw => m0_cal_hv_pw0,
phase_delay => m0_phase_delay0,
stdn => stdn,
break_duration_reg => break_duration_reg
M0_pulser_block1: pulser
port map
clk_64m => clk_64m,
reset_n => reset_n,
piezo_p => m0_piezo_lg_p(1),
piezo_n => m0_piezo_lg_n(1),
fire_busy => m0_fire_busy(1),
hifu_hv_pw => m0_hifu_hv_pw1,
cal_hv_pw => m0_cal_hv_pw1,
phase_delay => m0_phase_delay1
stdn => stdn,
You will need to declare your register as two dimensional array then apply:
for i in 1 to 2 generate ...
can I do something like this ?
many thanks!!!!
1. ARCHITECTURE
COMPONENT pulser
PORT
hifu_hv_pw :in std_logic_vector ( 7 downto 0 ) --0->15 hifu_pw
END COMPONENT;
2.ARCHITECTURE
type m0 is array (1 downto 0) of std_logic_vector(7 downto 0);
signal array_pw: m0 ;
3. BEGIN
hifu_hv_pw0<="01010101";
hifu_hv_pw1<="11111111";
array_pw <= hifu_hv_pw1 & hifu_hv_pw0 ;
4. PORT MAP
puls : for n in 1 downto 0 generate
pulser_port:pulser
port map
hifu_hv_pw => array_pw(n)
end generate puls;
you got the idea.
But assign as follows:
array_pw(1) <= "11111111";
array_pw(0) <= "01010101";
Many thanks for you help.
I have one more question related to my design,
I have another component that has lots of registers (120 registers 8bit each).
In this case I can declare an Array in side this component.
my quaestion is:
can I drive it out of this component to the top level?
I was trying to do that with no success, how should I define this output?
ENTITY registers IS
PORT (
my_array :out -- .....??
END;
But be careful about multiple drive
I opened a new thead relating this quastion, so nobody will be confuse.
thanks
