- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
How to get clock name on which the register is running in Q std?solved only using get_path, but during synthesis I get an error because get_path is not from sdc or sdc_ext package
- Tags:
- Clock
- time quest
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
where do you plan to put this get_register? Are you planning to put it in *.sdc? If yes, you may have to run timing analyzer to get the correct nodes.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
To find the correct nodes, what you can do is go to Timing analyzer -> Constrain -> set_multiclycle_path -> select the nodes that you want.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
set_clock_groups -physically_exclusive -group [get_clocks {clk}] -group [get_clocks {vidi_clock}]
however, in the toplevel file, these clocks are named differently. And I would like to use this module in other projects. That is, create an IP core and just use
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
If you want to name the clocks differently for timing analysis, in your clock constraints (create_clock or create_generated_clock), use the -name option. This won't change their names in the design, however.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It will be still the same, have to try to look for nodes by:
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
any further queries?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Yes, how does set_multicycle_path help me do my path analysis correctly?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I think multicycle is just being given as an example of accessing one of the GUI dialog boxes to access the Name Finder tool. There's no way to search for nodes in the timing netlist without going through one of these dialog boxes and I guess multicycle was selected just as an example. You don't need multicycle for the design.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
even worse, I don't need a graphical interface. i want to describe in sdc
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
True, but the GUI dialog boxes make it easy to form SDC constraints with correct syntax and they're the only way to get to the Name Finder.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
that is, there is no analog of entity-bound SDC files for quartus std?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Can you describe more on the previous question?
Once you set multicylce, you should be able to open up timing analyzer to analyze for that path.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
any update?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Ok, how to describe this multiplexer correctly? But "my module" must be used in different projects, and i don't know whats clocks used on "Tol level"
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Usually, Multiplexer does not consist of a clock. Does your Mux have a clock? If no, you do not need to set any clock for it. Timing analyzer analyze the path from register to register, once you have a register, you should have a clock to be constraint.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
My multiplexer switches the clock. And to describe it, you need to describe the clock groups
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Is this the multiplexer that you are working at?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
yes, but clkA and clkB on Top, to which I have no access and I do not know anything about it
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
