.jic File Creation
GLees
New Contributor II
I'm using an EP4CE30 device and Quartus Prime Lite version 21.1.0.  When I try to create a .jic programming file the "Configuration Device" selection shows only EPCQL1024.  There are no other choices available.  I'm using an EPCQ64A configuration device.
If I create my .jic file using the EPCQL1024 as my configuration device, my board fails when trying to program it.
YuanLi_S_Intel
Hi, can you click the ... button beside it? You can select the other configuration device in that option. If the configuration device is not available, you need to create it with the setting. You may refer to link below for the option usage:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-gen-flash-programmer.pdf#page=15
YuanLi_S_Intel
