17255 Discussions
megawizard plugin does not launch
spapp2
Hello, i have quartus 16.1. i have a pll that is instantiated and the outputs are set in the project that was given to me. I am trying to open the pll setting to add another output, but cannot get megawizard plugin manager to launch. i do not have the option to launch it from the tool either since i do not see that in the dropdown. how do i get this to open? any pointers are greatly appreciated.
Vicky1
Please select the "IP Components" in Project Navigator & then open Parameter Editor as shown below(It will take few moments to open),
Vicky
spapp2
​Hi Vicky,
thanks for pointing this out. I see the below message once I do that. I have Quartus 16.1, i'm guessing installing 18.1 will fix this?
Failed to launch Megawizard plugin manager. PLL intel FPGA IP v18.1 could not be found in the specified library paths.
Vicky1
This may be a bug caused by re-branding of Intel IP.
Until this is fixed, you can fix this like below,
 > locate the .lst file of the missing IP in your IntelFGPA program directory(C:\intelFPGA_lite\18.1\ip\altera\altera_iopll), for example for the missing PLL, locate: "altera_iopll_wizard.lst"
> Change the text:
 "<ALIAS>Altera PLL v16.1</ALIAS> "
 (and higher version numbers) to:
"<ALIAS>PLL Intel FPGA IP v16.1</ALIAS>"
make a entry until "<ALIAS>PLL Intel FPGA IP v18.1</ALIAS>" in .lst file & save & then try to open parameter editor.
please let me know , how it works to you.
Vicky
