17257 Discussions
memory export via tcl commands in cmd
RonBuzaglo
I wish to export the memory content via the command prompt, instead of using the In-System Memory Editor. so far I've tried :
quartus_stp_tcl --tcl_eval begin_memory_edit -hardware_name "DE-SoC \[USB-1\]" -device_name "@2: 5CSEBA6(.|ES)/5CSEMA6/.. (0x02D020DD)"
which gives :
Error (261020): The modifiable node at index 0 had been accessed by another program
Error (261020): The modifiable node at index 1 had been accessed by another program
Error (261020): The modifiable node at index 2 had been accessed by another program
even tried  the following command:
quartus_stp_tcl --tcl_eval get_editable_mem_instances -hardware_name "DE-SoC \[USB-1\]" -device_name "@2: 5CSEBA6(.|ES)/5CSEMA6/.. (0x02D020DD)"
which gives :
{0 256 1280 RW ROM/RAM NONE} {1 256 1280 RW ROM/RAM NONE} {2 256 1280 RW ROM/RAM NONE}
now the purpose of all this is the following command :
quartus_stp_tcl --tcl_eval save_content_from_memory_to_file -instance_index 0 -mem_file_path "exp_red.hex" -mem_file_type hex
which gives :
ERROR: A memory edit sequence has not been started.
while executing
"save_content_from_memory_to_file -instance_index 0 -mem_file_path exp_red.hex -mem_file_type hex
i dont understand what other program is interfering with my attempt to export said memory.
also, it seems by the error above that the "begin_memory_edit" command doesnt work properly....
i would like to note the fact that attempting to do the following process manually (via quartus in system memory content editor) works beautifully (meaning that exporting the hex files is successfull and even the data itself is correct - my project works  )
pleas help me do this automatically with these commands
thanks to whoever replies in advance
RonBuzaglo
everything works!!!!
thank you very much
sstrell
I'm not sure where you are getting the command "quartus_stp_tcl".  That's not a valid command that I've ever seen.  To see all the correct commands, open the Tcl console in Quartus from the View menu and click the little ? icon to open the Tcl and command line help.  To load the insystem_memory_edit Tcl API package, the executable is just "quartus_stp".
RonBuzaglo
hi
thank you for replying
i was working with quartus_stp_tcl becuase quartus_stp gave me the same errors so i saw no difference ...
although you gave me the idea of looking at "quartus_stp -help" which led me to "quartus_stp -s"
now the cmd turns into a tcl terminal , so i dont need the "--tcl_eval" anymore.
everything works !!!! i successfully exported the memory data from the fpga .
thank you so much!
i now wish to write everything to a simple tcl script to so when i open cmd
i will only need the "quartus_stp -t" command and the file ofcourse
how do i do that?
would the following be enough as a script?
do i need any other common commands prior or after this?
###########script starts here#################
read_content_from_memory -instance_index 0 -content_in_hex -start_address 0 -word_count 256
read_content_from_memory -instance_index 1 -content_in_hex -start_address 0 -word_count 256
read_content_from_memory -instance_index 2 -content_in_hex -start_address 0 -word_count 256
save_content_from_memory_to_file -instance_index 1 -mem_file_path "exp_green.hex" -mem_file_type hex
save_content_from_memory_to_file -instance_index 2 -mem_file_path "exp_blue.hex" -mem_file_type hex
###########script ends here#################
thanks again
sstrell
Looks good to me.  Can't hurt to try it.
RonBuzaglo
thank you very much
