passing value to tcl
s002wjh
is there anyway to pass value to a variable in side the tcl.  either from tcl console under quartus or using quartus_sh under linux?
for example
i have text.tcl, inside is
   set test  0
in my cmd line  i want to
quartus_sh  -t test.tcl  test =5
or in tcl console/
source test.tcl test=5
s002wjh
thx.  seem "exec" would work but everytime i try
exec quartus_sh -t top.tcl 5   it just freeze quartus
Heiko
You could do
quartus_sh -t test.tcl 5
And in test.tcl have
set test [lindex $argv 0]
That takes the zeroth input argument, in this case 5, and assigns it to a variable test.
RichardTanSY_Altera
May I know whether the suggestion from Heiko help in your case?
Do you need further help on this?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
s002wjh
it help on linux side, but what about tcl console in quartus?
when i try quartus_sh i got these errors
Error:invalid command name "quartus_sh"
Error:    while executing
Error:"unknown_original quartus_sh -t top_all.tcl 5"
Error:    ("eval" body line 1)
Error:    invoked from within
Error:"eval unknown_original $cmd $args"
Error:    (procedure "::unknown" line 7)
Error:"quartus_sh -t top_all.tcl 5"
Heiko
If you're running it from the tcl console the quartus_sh is not a valid command. Because (*I think) the tcl console in the quartus user interface is actually just the quartus_sh executable running in interactive mode.
To call quartus_sh from the tcl  console  you could use the exec command.
Following your example
exec quartus_sh -t top_all.tcl 5
Not sure if that is the most elegant solution to your problem. But it should work.
s002wjh
RichardTanSY_Altera
You may need to run it using command prompt. For best results, run shell commands and Intel® Quartus® Prime executables from a system command prompt outside of the Intel® Quartus® Prime software GUI.
Richard Tan
RichardTanSY_Altera
I believe that you got the answer to your inquiry. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
