$readmemb task trouble
名誉分销商 II
2,947 次查看
Hi Guys, I have a problem with $readmemb :( This is my code:
`timescale 1ns/100ps
`include "rom_sin_vec.txt"
module ROM_sin
input clk, rst,
input [10:0] addr,
output reg [11:0] data
reg [10:0] temp;
integer i;
reg [11:0] RAM_2048_12BIT [2047:0];
$readmemb ("rom_sin_vec.txt", RAM_2048_12BIT);
always @ (posedge clk or negedge rst)
begin
if (!rst)
data <= 12'b0;
else
if (clk)
begin
temp[10:0] = addr;
data = RAM_2048_12BIT[temp];
end
end
endmodule
And this is my txt file content
12'b000000000000
12'b000000000110
12'b111111111001
And when I compile my project, I got this error:
** Error: rom_sin_vec.txt(1): near "12": syntax error, unexpected "INTEGER NUMBER", expecting "class"
I'm using Modelsim-Altera Starter Edition, Version 6.5b
Who can tell me why this error occurs and how to fix it :( thank you so much
0 项奖励
3 回复数
名誉分销商 II
1,777 次查看
Try removing the 12'b from the file.
I've always just had the binary digits one data word per line. (In this case 12 binary digits)
Pete
0 项奖励
名誉分销商 II
1,777 次查看
I think remove "12'b" will work.
my project use hex data:
$readmemh("cos.txt", rom);
cos.txt:
7fff
7ff9
7fe6
7fc7
7f9a
7f62
7f1c
0 项奖励
名誉分销商 II
1,777 次查看
You should not have `include "rom_sin_vec.txt" in your code. It does not get compiled as Verilog syntax and you do not put 12'b in front of each word. The $readmemb task will read the file as binary text.
0 项奖励
回复
