- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi Guys, I have a problem with $readmemb :( This is my code:
`timescale 1ns/100ps `include "rom_sin_vec.txt" module ROM_sin ( input clk, rst, input [10:0] addr, output reg [11:0] data ); reg [10:0] temp; integer i; reg [11:0] RAM_2048_12BIT [2047:0]; $readmemb ("rom_sin_vec.txt", RAM_2048_12BIT); always @ (posedge clk or negedge rst) begin if (!rst) data <= 12'b0; else if (clk) begin temp[10:0] = addr; data = RAM_2048_12BIT[temp]; end end endmodule And this is my txt file content 12'b000000000000 12'b000000000110 ... 12'b111111111001 And when I compile my project, I got this error: ** Error: rom_sin_vec.txt(1): near "12": syntax error, unexpected "INTEGER NUMBER", expecting "class" I'm using Modelsim-Altera Starter Edition, Version 6.5b Who can tell me why this error occurs and how to fix it :( thank you so much- Balises:
- Intel® Quartus® Prime Software
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Try removing the 12'b from the file.
I've always just had the binary digits one data word per line. (In this case 12 binary digits) Pete- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I think remove "12'b" will work.
my project use hex data: $readmemh("cos.txt", rom); cos.txt: 7fff 7ff9 7fe6 7fc7 7f9a 7f62 7f1c- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You should not have `include "rom_sin_vec.txt" in your code. It does not get compiled as Verilog syntax and you do not put 12'b in front of each word. The $readmemb task will read the file as binary text.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
