Hi Guys, I have a problem with $readmemb :( This is my code:
`timescale 1ns/100ps `include "rom_sin_vec.txt" module ROM_sin ( input clk, rst, input [10:0] addr, output reg [11:0] data ); reg [10:0] temp; integer i; reg [11:0] RAM_2048_12BIT [2047:0]; $readmemb ("rom_sin_vec.txt", RAM_2048_12BIT); always @ (posedge clk or negedge rst) begin if (!rst) data <= 12'b0; else if (clk) begin temp[10:0] = addr; data = RAM_2048_12BIT[temp]; end end endmodule And this is my txt file content 12'b000000000000 12'b000000000110 ... 12'b111111111001 And when I compile my project, I got this error: ** Error: rom_sin_vec.txt(1): near "12": syntax error, unexpected "INTEGER NUMBER", expecting "class" I'm using Modelsim-Altera Starter Edition, Version 6.5b Who can tell me why this error occurs and how to fix it :( thank you so muchLink Copied
Try removing the 12'b from the file.
I've always just had the binary digits one data word per line. (In this case 12 binary digits) Pete- Mark as New
I think remove "12'b" will work.
my project use hex data: $readmemh("cos.txt", rom); cos.txt: 7fff 7ff9 7fe6 7fc7 7f9a 7f62 7f1c- Mark as New
You should not have `include "rom_sin_vec.txt" in your code. It does not get compiled as Verilog syntax and you do not put 12'b in front of each word. The $readmemb task will read the file as binary text.
