572 Discussions
ARM A9 bare matal IRQ priority can't work
TBaox
I use cyclone V HPS, and there is a problem in configuring interrupt priority. I gave OSC1 TIMER a higher priority, and after the program was executed, I found that it could not preempt the low priority external interrupt from FPGA. Look at the priority configuration MASK and binary point are lower 3 bits. Excuse me, where is my configuration wrong.
The OSC1 timer runs normally as shown in figure 2. after the interrupt from FPGA is enabled, the timer interrupt cannot run normally, as shown in figure 1
EBERLAZARE_I_Intel
Is the timer interrupt that you mentioned also could not run normal if if interrupt from other sources other than FPGA?
TBaox
I didn't try that.
But  IRQ from FPGA timer ip doesn't preempt the low priority external interrupt from FPGA pio,too.
So I think something wrong on my configation.
EBERLAZARE_I_Intel
May I know which Quartus version you are using? Also how did you compile/setup your preloader files?
TBaox
EBERLAZARE_I_Intel
TBaox
Sorry,I can't open the second link.
EBERLAZARE_I_Intel
Unfortunately, the link is no longer available.
May I know, how did you setup/configure the prioritization? Did you have the H2f/f2h bridges enabled?
TBaox
I use this function and I have enabled H2f bridge and light H2F bridge, unuse f2H bridge.
//set prioritization
alt_int_dist_priority_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ0,48);
EBERLAZARE_I_Intel
The Priority interrupts, ID0-ID15, that can only be triggered by software called Software Generated Interrupts (SGI).
Unfortunately, we do not have any official document on how this can be done, thus please refer to below suggestion from other discussion on the SGI configuration:
https://stackoverflow.com/questions/20430733/inter-processor-interrrupts-in-arm-cortex-a9-how-to-write-an-handler-for-softw
https://stackoverflow.com/questions/41851975/enable-and-distribute-irqs-in-linux
TBaox
EBERLAZARE_I_Intel
I found the documentation below on the Preemption on section 3.3, could you take a look:
https://developer.arm.com/documentation/ihi0048/bb
TBaox
