573 Discussions
technical assistance request ( s/o#605448)
JLiu18
Hi Tech,
part#FJ8067702739628S R33Z
PO: 029-UV722
QTY: 5
D/C: 2013
Lot Code: X013E402
Our customer received above parts and found they have coplanarity issue.
Please see attached pictures.
You can find part is tilted and deformed in different degrees, and there is a greater risk of empty soldering.
Could you help check and advise if parts defective or any other reason?
Maria_R_Intel
Hello JLiu18,
Thank you for posting on the Intel* Community.
To better assist you, please provide us with the below details:
  • Are you using an FPGA platform?
  • Is your customer a developer of hardware or software?
Maria R.
JLiu18
Hi Maria,
Our customer replied as below:
" Yes, it is right. We use 5CSXFC4C6U23C8N FPGA, Dual-core CORTEX-A9, 600MHz,672-UBGA.
And I am a hardware and software engineer.”
Maria_R_Intel
Hello JLiu18,
Thank you for the information.
To better assist you, we will move this thread to the proper sub-forum. Please expect a response soon.
Maria R.
Victor_G_Intel
Hello JLiu18,
Generally speaking, a bent or damaged substrate
should be returned as a defective part immediately.
Important note: I have sent you a private message with some extra information please review it.
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello JLiu18,
We will proceed to close this thread; however, if you need any additional information; you are more than welcome to submit a new question just remember that this thread will no longer be monitored.
Victor G.
