SPARSE_STATUS_NOT_SUPPORTED exit status in mkl_sparse_sp2m with symmetric sparse matrices
yera__rolando
Hi
I'm trying to multiply to symmetric sparse matrices using the mkl_sparse_sp2m function, the exit status is SPARSE_STATUS_NOT_SUPPORTED and i don't understand why, here goes the reproducer. I'm using mkl 2019 update 4 in debian.
Gennady_F_Intel
That's mean the current implementation doesn't cover this set of input options.
Kirill_V_Intel
Gennady is right, this case is not supported currently in mkl_sparse_sp2m.
Though this case is supported by mkl_sparse_spmm as far as I see. So, is there a particular reason why you want to call sp2m here?
Best,
Kirill
yera__rolando
Hello:
Yes this particular case is supported by mkl_sparse_spmm, the reason why I use mkl_sparse_sp2m is because in my real application I wanted to store only the symmetric part of the matrix on CSR format (this is not the case of the reproducer), now I know that this case is not supported currently so I will store all the matrix and use mkl_sparse_spmm.
pd: Sorry about the english
Gennady_F_Intel
MKL 2020 has been released on Dec 12 and this version still doesn't support these matrixes. We only add some note: "Currently, only SPARSE_MATRIX_TYPE_GENERAL is supported.". In the case, if you are interested to extend the supported matrix, please fill the request into Intel Online Service Center.
