--- Genuine Intel Test ---
Version 1.0.16.64b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.20.64b.W
IntelR CoreTM i3 CPU 550 3.20GHz
Brand String Module Success....
--- Cache Test ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size -- 32
- Detected L1 Inst Cache Size -- 32
- Detected L2 Cache Size -- 256
- Detected L3 Cache Size -- 4096
Cache Module Success
--- MMXSSE Test ---
Version 1.0.22.64b.W
..DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
Testing MMX
Dot Product computed using C code 506
Dot Product computed using MMX intrinsics 506
MMX Dot Product Computation Test Passed
Passed MMX Test
Testing SSE
Dot Product computed using SSE intrinsics 506
SSE Dot Product Computation Test Passed
Passed SSE Test
Testing SSE2
Complex Product computed using C code 23.00 -2.00i
Complex Product computed using SSE2 code 23.00 -2.00i
SSE2 Complex Product Computation Test Passed
Passed SSE2 Test
Testing SSE3
Complex Product using C code 23.00 -2.00i
Complex Product using SSE3 code 23.00 -2.00i
SSE3 Complex Product Computation Test Passed
Passed SSE3 Test
Testing SSSE3
SSSE3 Absolute Value Tests Passed
SSSE3 Arithmetic Tests Passed
SSSE3 Dot Product Test Passed
Passed SSSE3 Test
Testing SSE4.1
SSE4.1 Blend Tests Passed
SSE4.1 Min Max Tests Passed
SSE4.1 Insert Bit Tests Passed
SSE4.1 Extract Bit Tests Passed
SSE4.1 Bitwise Comparison Tests Passed
SSE4.1 Dot Product Test Passed
SSE4.1 Arithmetic Tests Passed
SSE4.1 Bit Conversion Tests Passed
SSE4.1 Bit Compare Test Passed
Passed SSE4.1 Test
Testing SSE4.2
SSE4.2 Bit Compare Test Passed
SSE4.2 Calculate Bit Set to 1 Test Passed
SSE4.2 CRC Test Passed
Passed SSE4.2 Test
MMXSSE Module Success
--- Integrated Memory Controller Test ---
Version 1.0.17.64b.W
--- Reading Memory Size ---
Detected Memory Size is -- 4.00GB
--- Subtest - Memory Size Test Passed ---
--- Integrated Memory Controller Test Passed ---
Parallel_PrimeNum_i3
Version - 1.0.0.9
Parsing Parallel_PrimeNum_i3.xml
Running Module Math_PrimeNum.exe -s 20 -resultName Math_PrimeNum_Parallel_PrimeNum_i3_1_Results.txt
Running Module VisParticle.exe -ps 1.0 -ws 700 -s 20 -resultName VisParticle_Parallel_PrimeNum_i3_1_Results.txt
--- Prime Number Generation Test ---
AVX is NOT supported in your OS
Ops Per Sec CycleRun Error Timesec
376388 1 0 1
323098 2 0 2
697318 4 0 3
721802 6 0 4
356270 7 0 5
587430 9 0 6
679136 11 0 7
622113 13 0 8
330936 14 0 9
673758 16 0 10
704829 18 0 11
617889 20 0 12
592523 22 0 13
623815 24 0 14
296219 25 0 15
611536 27 0 16
646500 29 0 17
626362 31 0 18
580215 33 0 19
619626 35 0 20
Operation Per Second -- 619626
Error -- 0
Prime Number Generation Test Passed
Module Math_PrimeNum.exe Completed - Pass
Module VisParticle.exe Completed - Fail
No valid errorcode returned
Error Code -1073741819
Result - Fail
As you've seen, the IPDT tool doesn't work all that well with ancient, 1st gen. Core processors. Your processor is not supported on Windows 10. While Windows 10 will run, there are no performance guarantees for older unsupported processors like yours.
Adding more memory will help a little bit, but I really consider this throwing good money for bad. Really, the only proper solution for your concerns is to get a newer processor (at least a 7th gen.). This will mean a new motherboard and new memory (you'll be transitioning from DDR3 to DDR4) as well. Sorry there isn't a better answer.
Reality bites,
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
