Items with no label
3338 Discussions
I would like to use SR300 with Unity
SKim61
I am trying to use SR300 with Unity however I am not able to detect the device.
I followed link : https://software.intel.com/en-us/forums/realsense/topic/564571 [Solved] Fix error when open sample project realsense in Unity 5
Which has compiled plugin x64 version.
My error is
SenseManager Initialization Failed
UnityEngine.Debug:LogError(Object)
RawDataCapture:Start() (at Assets/Scripts/RawDataCapture.cs:35)
Code:
void Start () {
/* Initialize a PXCMSenseManager instance */
psm = PXCMSenseManager.CreateInstance();
if (psm == null){
Debug.LogError("SenseManager Initialization Failed");
return;
What should I do to get move on?
MartyG
I compared the SenseManager code you used to a script by another user that used identical code and noted that in their script's header section above the Start() function, they had this setup line for the Sense Manager:
private PXCMSenseManager psm; //SenseManager Instance
Have you got this in your script?
