16771 Discussions
İ7 1400K games crash
Fatihsy
Hello, games freeze and take to the desktop with i7 14700k processor and 7200mhz ram frequency. There is no problem with lower ram frequency.
-bios latest version updated
-default intel settings
İ7 14700K
MSI Z790 CARBON
G.Skill 32GB(2x16) Trident Z5 RGB 7200mhz CL34 DDR5 Ram
What do you think is the problem? Is the processor damaged?
Mike_Intel
Hello Fatihsy,
For the BSOD and/or stability issue for your processor, kindly open the community link where we posted our recommendations and follow the provided settings that you need to set inside the BIOS then tell us if there is an improvement.
https://community.intel.com/t5/Processors/Updated-Guidance-RE-Reports-of-13th-14th-Gen-Unlocked-Desktop/m-p/1594553
If you are still having the same issue after trying these settings, you may need to contact your local warranty support for the replacement of the processor.
Michael L.
Mike_Intel
Hello Fatihsy,
Michael L.
Mike_Intel
Hello Fatihsy,
I am sending another follow up to check if the last recommendation worked.
Michael L.
Fatihsy
Hello, I just had the chance to try it and I tried all the settings but the games are crashing and not working properly at ddr5 7200 mt/s.
