16801 Discussions
After Speed Optimizing with XTU, i cant undo neither change my active P-cores
ThorbenS
Today i tried optimizing my i7-10700K bc i only run it on 3,6Ghz, i tried Auto Optimizing at first but it cranked my active p-cores right away to 47x (4,7Ghz) which is way to high, i gett rlly high temp now. I cant change any importand settings in the advanced tuning section either for some reason.
Pls Help
Mike_Intel
Hello ThorbenS,
  1. Let me clarify, are you trying to overclock your processor?
  2. Before that, you are you also having issues with the processor?
  3. Can you also provide the exact issue that you encounter while trying to optimize the processor?
Michael L.
ThorbenS
Np, so I tried Overclocking my processore for the first time, bc i run into a problem in a rlly cpu heavy game (Borderland 4), before that ive never had any issues with my cpu.
So what i did is looking up in YT how do overclock my CPU using XTU.
For that i disabled the coreisolation for windows security and enabled something in the Bios to run XTU.
In the program itself i only ran a benchmark test and than i decided to run auto Optimizition.
After that i saw that 47x p-core (36x before) was active, and i allready knew that this would prob. cause a heat problem, i treid reducing that somehow but how u can see in the screenshot i can bc every important setting is greyed out.
I even tried going in Borderland and right at the start i hitted 96° so i closed it right away, i also tried:
Reinstalling,
Setting my XTU profile to Default,
Turning Coreisolation on again,
Deactivating the 1 setting in bios again,
But i still cant redo the 4,6GHz change from XTU, and idk what exactly to change in my Bios to redo it there too, i tried looking for the option there fo maybe change it again but i didnt found it, also idk if i can set the wolt setting etc from XTU back to normal (The ble linea in the screenshot) bc idk if thats safe if i cant also set my active P-Cores back to ig 36x (3,6Ghz).
I hope that helps u understand my Problem more, if u got any more Questions feel free to ask
Mike_Intel
Hello ThorbenS,
Thank you for the update.
Please note that we do not support overclocking because altering clock frequency or voltage may void any product warranties and reduce stability, security, performance, and life of the processor and other components. Check with system and component manufacturers for details.
I can only share the following links, and you may also seek assistance from other forum users here:
What Are the Hardware Requirements for Overclocking an Intel®...
How to Obtain Information About Overclocking Intel® Processors
How to Overclock Your Unlocked Intel® Core™ Processor
Michael L.
