- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I have a 1215U model processor. I would be very grateful if you could answer all my questions below.
-15W for PL1 on intel specs. 55W is reported for the PL2. Would it be a problem to set PL1 to 20W and PL2 to 55W in BIOS settings?
-If I take the PL1 value out of the intel standards, will it cause any problems other than the temperature? If I have a good cooling system, can I play with the PL1 value?
-Is it possible for you to explain what the PL1, PL2, PL3 and PL4 values are one by one, and what problems will I encounter when I play with these values?
Thank you very much.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello aydinsenol,
Thank you for posting on the Intel
To know what your hardware is and to have a better understanding of the situation, please answer the following questions:
- Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello aydinsenol,
Andres P.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello aydinsenol,
Andres P.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
