16774 Diskussionen
Intel XTU Vers. 7.14.2.45 / i5-13600K - Automatic Overclock and Optimization is not supported
NathanielZ
Einsteiger
1.133Aufrufe
Good morning.
Intel XTU does not work, even though the processor is listed as supported, MB firmware is the latest, and BIOS settings appear to be correct (followed the instructions in other threads' solutions from moderators).
Attached are the screnshots and logs.
5 Antworten
ArchieD_Intel
1.074Aufrufe
Hi NathanielZ,
When did the issue start? Was it after a specific update?
What are the troubleshooting steps that you tried so far?
Have you tried reinstalling the XTU and followed How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU)?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
NathanielZ
Einsteiger
918Aufrufe
Good afternoon, Archie.
1. The issue was there when I first tried to use the software (Intel XTU). I have never used it before - this was my first time downloading it.
2. To troubleshoot the problem, I read through the forum topics with the same issue on the same CPU. Specifically, I have checked the BIOS settings like auto overclock is set to auto and not manual, XMP is on auto, etc. I have also tried to downgrade the version with modified xml file that was provided in another thread but to no avail.
3. Yes, I also have tried the uninstallation steps in the guide you provided above.
None of these steps helped.
I have downloaded the SSU and generated the report. Find it in attachements.
Thank you!
ArchieD_Intel
844Aufrufe
Hi NathanielZ,
Thank you for the feedback. I will investigate this and will update you as soon as possible. Thank you for your patience.
Archie D.
ArchieD_Intel
766Aufrufe
Hi NathanielZ,
I want to inform you that this is a known issue, and Intel is actively working to address it. I appreciate your patience and understanding as we work towards a solution. Once again, I will be updating you once I have a solution.
Archie D.
ArchieD_Intel
499Aufrufe
Hi NathanielZ,
I would like to inform you that Intel is aware of the issue you are experiencing. A fix is currently being developed and will be released in future updates. We appreciate your patience and understanding as we work to resolve this matter.
Archie D.
Antworten
