16771 Discusiones
i9 14900k - Gaming Issues
Zlicer
Principiante
23.961 Vistas
Good Morning,
I hope this email finds you well,
I bought a new PC not long ago - and I have been encountering many issues while playing in 3 games so far..
The Finals, The Last of Us Part 1, Monster Hunter Rise as well as World and Jedi Survival won't open and in some of them I will get a message I don't have enough graphic memory - but I have a 4090 and 64gb ddr5 ram
The only way I make this games work was by installing Intel(R) Extreme Tuning Utility - and turn the Performance Core Ratio from 57x to 52x - is this normal? would this be always required? am I missing something?
Kind Regards,
Eli
Etiquetas (1)
0 kudos
11 Respuestas
Jose_Intel
Empleados
23.902 Vistas
Hello @Zlicer
Thank you for posting on the Intel️® communities.
We sincerely regret you are experiencing issues with your Intel® Core™ i9-14900KF Processor, we will be more than happy to assist you.
Please answer the following:
·      Was it working before?
·      Have you made any recent software change?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the report from the Intel® Processor Diagnostic Tool.
Jose B.
Zlicer
Principiante
23.897 Vistas
Hello Jose,
Thanks for the answer,
Mine is a Intel® Core™ i9-14900K Processor without the F.
To your questions:
I don't think so, I purchased the computer 2 months ago, so possibly not.
I am not sure if I made any software changes to be honest - but as said below I can only play said games doing this
"installing Intel(R) Extreme Tuning Utility - and turn the Performance Core Ratio from 57x to 52x"
And I am not sure if that is normal.
Please find attached documents requested - the test from Diagnostic Tool - the first time Failed in the Prime Number - then I did it twice more and it was completely fine.
Kind Regards,
Eli
Jose_Intel
Empleados
23.860 Vistas
Hello Zlicer
Thank you for your reply and the reports.
We noticed that the configured memory clock speed is beyond Intel’s specifications, please disable any overclocking and set the frequency to the maximum supported (5600 MT/s) by your Intel® Core™ i9-14900K Processor.
Also, please make sure the graphics driver and Windows are up to date. Let us know the outcome.
Jose B.
Zlicer
Principiante
23.821 Vistas
Hello Jose,
Thank you very much for the above,
You are a lifesaver - so apparently the base speed for my CPU in the bios was set up as x57 or 5.7 Ghz - that probably caused the issue, which is weird in the Intel(R) Extreme Tuning Utility - shows x57 as default - but I haven't changed any of those settings, is there a way to put it as default?
How can I leave everything as I was when I bought it? - I think that probably would resolve every issue - as per picture attached is "Manually Tunned" - Perfomance Core Ratio x32 and Efficient Core Ratio x44.
Thank you very much for this again!, you really helped me here.
Kind Regards,
Eli
Jose_Intel
Empleados
23.756 Vistas
Hello Zlicer
Thank you for letting us know.
Please keep in mind that the default settings of Intel® XTU are found on the board's BIOS.
If a profile is set from the Intel® XTU with a specific value, follow the steps below:
1.    Back up any Intel® XTU profile before reinstalling the program to avoid losing settings.
2.    Reinstall Intel® XTU.
3.    Load BIOS default to apply the default settings.
Jose B.
Jose_Intel
Empleados
23.672 Vistas
Hello Zlicer
We hope you are doing fine.
Were you able to follow the previous steps?
Jose B.
Zlicer
Principiante
23.552 Vistas
Hello Jose,
Thank you very much for checking!, to be honest I haven't been able to fix this yet - as per the picture attached, bios show as modified by the AI but It's set up as normal, also I uninstalled the Armoury Crate as per Asus indications but still shows the CPU at 5700, so I am bit lost!
any help could be appreciated, would it work if I turn the computer and power off and remove the battery from the mother board? or that would be too much?
Kind Regards,
Eli
Jose_Intel
Empleados
23.420 Vistas
Hello Zlicer
Thank you for your reply.
Please keep in mind that the previous steps were recommended to have your system with the default settings, meaning no overclocking.
If you require further assistance with the motherboard settings, please contact the system manufacturer. https://rog.asus.com/us/support
Jose B.
terrorbyte
Principiante
23.096 Vistas
Hello everyone, I seem to be having the same issue as Zlicer, I have an i9 14900KF and lots of games only seem to work if I set the Performance Core Ratio to 5.2.
These problems are happening in Call of Duty and Ready or Not for me as well. Can I get a quick check up to see what's the issue in my case and hopefully get a guide on how I would fix it? I didn't change anything from the stock settings, at least not on purpose.
Wdogit
Principiante
17.990 Vistas
I’m having the same issues 14900k but I’ve been able to game at x57 and pcore at x45-46 however turning on the boost in cpu settings in the bios boosts 1-4 cores to x6o-x61 and having watch when the boost happens the game stops no matter which game it’s like someone hit a light switch no error … I’ve. Also noticed asus strix a 790 board thier bios says auto but boots at 100.25 and if I set it to 100 in the bios it crashes so the whole system is being tweaked at 100.25 so my memory is rated skill 6000 MHz I’ve set it back to 5900 or 5800 and turn off boost mode in the cpu and can game crash free at x57
RalphieVII
Principiante
13.248 Vistas
Hello Intel team,
I have been running into the same gaming issues with my gaming PC which is a similar setup to many on here with 14900kf, Nvidia 4090 GPU and 64 GB RAM.  I have updated my BIOS and all of my drivers but getting access violation errors on World of Warcraft and Final Fantasy 14.
Can you take a look at my attached report and let me know if anything is outside of recommended specification?
Also, if I need to make changes can you provide direction on what I need to do?
Thank you!
Responder
