12748 Discussions
NIOS II Problem with Interrupt Timer
I'm using the Cyclone II Development Kit. Using SOPC builder I added a timer to the NIOS2 in "standard" project. I configured the timer to be an Interrupt timer with a period of 500 microseconds. I assigned the it an IRQ of 7 and a slave address immediately following the periphal address of the previous element (0x022208C0). I generated a new processor and then compiled it in Quartus II. In the software I wrote and interrupt function, installed it, and enabled it. I read the status and control registers of the timer and confirmed that the timer is running, it times out, and the interrupt enable bit is high; but alas the interrupt code never gets called. What am I doing wrong?? Any hints or comments would be greatly appreciated.
I used something like
 /* set to free running mode */  IOWR_ALTERA_AVALON_TIMER_CONTROL (HIGH_RES_TIMER_BASE,            ALTERA_AVALON_TIMER_CONTROL_ITO_MSK  |            ALTERA_AVALON_TIMER_CONTROL_CONT_MSK |            ALTERA_AVALON_TIMER_CONTROL_START_MSK);  /* register the interrupt handler, and enable the interrupt */      alt_irq_register (HIGH_RES_TIMER_IRQ, NULL, handle_timer_interrupt);
to program the highres timer in the standard example... It worked for me.
Paolo
--- Quote Start ---
originally posted by paolo.gai@Mar 20 2006, 11:47 AM
i used something like
 /* set to free running mode */  iowr_altera_avalon_timer_control (high_res_timer_base,            altera_avalon_timer_control_ito_msk  |            altera_avalon_timer_control_cont_msk |            altera_avalon_timer_control_start_msk);  /* register the interrupt handler, and enable the interrupt */      alt_irq_register (high_res_timer_irq, null, handle_timer_interrupt);
to program the highres timer in the standard example... it worked for me.
paolo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13611)</div>
--- Quote End ---
--- Quote Start ---
originally posted by dough1a+mar 20 2006, 01:38 pm--><div class='quotetop'>quote (dough1a @ mar 20 2006, 01:38 pm)</div>
--- quote start ---
<!--quotebegin-paolo.gai@Mar 20 2006, 11:47 AM
paolo
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13614)</div>
[/b]
--- Quote End ---
Thanks. I used the same code for the highres timer and it worked fine; but when I add an additional timer with the same attributes as the highres timer I can&#39;t seem to get the interrupt to be generated.
Doug
