Timer
good evening to everybody
Sorry for my english , i'm italian
I'm a Plc-Pc programmer , and now i start this new adventure
with fpga .I order , and waiting too , a stratix2 dev. board.
In the meantime , i my free time , a started to download and study
different .pdf files from Altera , about Nios II , Quartus II , and else .
I want to ask if is possible create a vhdl file , describeing a component Timer
;this component will accept these parameters :
-start
-stop
-Preset
Like using timer in plc , TON and TOF timer.
In his hw it elaborate every 100 ms a counter if the start-bit is true ,and when
the the counter il >= then Preset it return Done .
In Nios II ide i want to use like this
IF (mycondition=true)
Timer.start=true;
Timer.Preset=1000; // 1 Sec
else
Timer.stop=true;
Timer.start=false;
...........................// other logical
IF (Timer.done=true)
//.......excute something
When i test done my Timer , i can to use a lot of this component .
It's possible make this using SOPC?
i suppose "of course" , but how ?
Regards and thanks
Walter
Sorry
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
I open just now Quartus II and try SOPC application , and i saw that
timer component already exists , and i gave a lot of timer in my system
without problem
I suppose only limitation is the memory , but i think i can to use many timers
But can i set register interval from NIOS II IDE ?
thanks
Walter
walter,
In short....yes. You can find more information.... here (http://www.altera.com/literature/lit-nio2.jsp).
Cheers, and enjoy the reading http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
- slacker
yes
i had download these files just last week
i have all documentation
thanks !!!
walter
