12748 Discussions
is command line programming tools available to program Arria 10 FPGA from Green hills integrity RTOS? How to get the NIOS II command line tools which runs on the Green hills integrity RTOS.
sR2
Nooraini_Y_Intel
You can only use the Quartus tools which include the command line programming tool and NIOS within the supported OS as shown in the link here:
http://fpgasoftware.intel.com/requirements/18.0/
Nooraini
sR2
Hi Nooraini,
Thank you for your response. Is there any other way to program Intel FPGA from Green Hills integrity RTOS? or is it possible to get the source code of those NIOS utilities?
Nooraini_Y_Intel
Hi sR2,
The Quartus tools are not open source software. Perhaps you can try to consider using the supporting OS for example Ubuntu 16.04 does support Quartus tools.
Nooraini
