Hello:
Now my flash can't use the IDE to program.I think a method that if I can use another software to program the .bin file to flash,then I write a avalon_interface to communicate between flash and nioscpu. if this is ok,I will use the below code to read data from flash. code : unsigned char *data; k=(unsigned char*) flash_base;//read data from flash //k=(unsigned cahr *) ram-base;//read data from ram for (i=0;i<=100;i++) data=k ; But now I have a problem : if I can't write command word to flash ,I can read data from flash ? It means that I can directly read data from flash as read data from ram.because above code can directly read data from ram. Thank you!链接已复制
0 回复数
