OpenCL* for CPU
公告
1733 討論
How to debug a crash on Intel SDK ?
Polar01
初學者
1,261 檢視
In my application I run my kernels several times (1 to 50000 times). All the steps use the same kernel and approximatively do the same work. But, after a few time (40 steps) the application in some context crash !
But where !!??
Is there a way to know where an OpenCL application crash ?
0 積分
7 回應
Evgeny_F_Intel
1,261 檢視
If you use Visual Studio you can look in output window and see where do you have the exception.
In linux, you can use GDB and then load and analyze core dump.
Polar01
初學者
1,261 檢視
Thanks Evgeny,
I use Visual Studio 2008 and only got the following message :
First-chance exception at 0x0fb2c160 in pureStudio.exe: 0xC0000005: Access violation writing location 0x1dd4fffc.
Unhandled exception at 0x0fb2c160 in pureStudio.exe: 0xC0000005: Access violation writing location 0x1dd4fffc.
But I don't know where (in my OpenCL kernel) the application crash :-(
Polar01
初學者
1,261 檢視
What I have notice is that if I change my "build options" to "-g -cl-opt-disable", then I have NO crash !
Evgeny_F_Intel
1,261 檢視
The issue might be in some compiler optimization.
Can you provide small reprodusor?
Evgeny
Polar01
初學者
1,261 檢視
Hi Evgeny,
Unfortunately no ! The software is a big application I'm working on it since 2 years now !
It is difficult to know "where" the crash occur, I have no information in the output, just that VS2008 show me a 'dissassemble' window with some assembly code !
My current task is to stabilize the software, and first, with the Intel SDK.
What I can do is to provide to someone of Intel an access to the code repository ! Or simply provide a "debug" version of the software too ?
In fact I hope to release the software soon, but first I must be sure that it work with at least one SDK. So, do you think that we can find an agreement with Intel to insure that the application work (before the release of the SDK) ? and why not... my application can serve as a "showcase" ?
Krys
Polar01
初學者
1,261 檢視
So,
How can I help you to fix the problem ?
BTW: it will be fine to have a tool to debug and find memory leaks that occurs in the OpenCL kernel. Today, when a crash occur... we have no idea of the reason of this crash (and where it occur).
Evgeny_F_Intel
1,261 檢視
I'm sorry, but the only way we can help if you can provide small reprodosor for the issue.
OpenCL products are emerging and maybe you can find a tool that can help you.
回覆
