I want information regarding processors etc for programming purpose. I will be very glad if you please reply me though Email ID. So that I can ask questions freely when ever I need to ask.
There are hundreds of processors. You need to be more specific as to what you want. And, there is no communication over email. It is done via this forum, and you can be notified when a response is provided.
Doc
No, this cannot be done.
Doc
What you are asking cannot be done.
Doc
"Doc" is my nickname.
None of what you are stating and asking makes any sense. Even so, no computer can be provided.
Doc
This is the unregistered laptop. The battery is dead, cmos battery is also dead, keypad is hard. It has a problem with over heating too. I pasted a sticker on the track pad to protect it from scratches. I have seen this laptop turns on automatically when ever I put in on charge, may be because the power button is defected too. But sometimes it works too. Cmos battery is creates trouble in using internet too. As I use to connect to the internet and then I update the time using the internet. Then only I can use the internet to search information by open any browser. Otherwise it does not let me use the internet to search the needed information. I use cracked version of windows. As I do not have that much money though to purchase it. I use activator prepared by the hackers around the globe to break the security codes of Microsoft.
I think Mr. Gates should do something to stop the hacking procedure rather than inventing any other version of OS sooner. There are already several computer repairing stores are available in the market which installs pirated version of OS with only Rs.200 or Rs.500. Mr. Gates should alter the language if possible to protect his company from the hackers. I think alteration of programming language is not a bad option if it is not possible to make a new language. Otherwise Mr. Gates should do something in a way that can prevent the hackers from cracking codes including systems to operate using pirated version of windows.
I think there is another possible option available.
Mr. Gates should prepare a language by altering the existing or inventing a new one, to write codes which can be downloaded right after one connects the PC to the internet. Because no one will want to buy a computer without having to use the internet connection. Just like the mobile phones or browsers drop their unnecessary apps without our knowledge.
But the plan needs some modification. Only dropping the software is not enough. Mr. Gates should prepare that software in a way that can protect the company from hackers permanently. You do not have all the day to fight against the hackers. You make a wall. AND let the wall defend itself.
If the writing new language is not possible then alter the existing one. If that too is not possible then make the software stronger enough in a way that new language becomes unnecessary to write.
Grab their system IDs, and block them from accessing the internet without using a original version of software.
Look, if a person can purchase computer for his personal usage, then it is obvious that the person can afford purchasing the Operating System as well.
If you have to use internet from computers then either build an OS for yourself, otherwise use the existing OS by purchasing it.
Stop all of this drivel. And, complaining here about Bill Gates is simply stupid.
Doc
