I recently bought Intel I5 13500 processor. Why are temperatures reaching high on it? Fan runs fast. I did CPU stress test via Intel XTU software and temperature reach more than 100 degrees; thermal throttling is also observed. Why is it so?
Vinay23, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
For this scenario, it is important to mention, that it is expected for the processor to reach high temperatures when you perform a stress test on it since you are pushing it to its maximum capacity. It is also necessary to note that the Intel® XTU is not fully compatible with your unit since the toll works with Intel® Core™ Processors that include the letters K, KF, HK, X, and XE in their processor number:
In order to rule out a possible hardware issue with the unit, please install and run the Intel® Processor Diagnostic Tool, it does an overall test on the processor and if it passes the test it means it is working properly:
Additionally, in the following link, you will find the "Overheating Symptoms and Troubleshooting for Intel® Boxed Processors" with further details about this topic:
If the issue persists after that, in order for us to provide the most accurate assistance on this subject, we just wanted to confirm:
Is this a new computer?
Was this specific machine working fine before without showing overheating issues?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Albert R.
Hello Vinay23, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Hello Vinay23, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
