Just bought a new PC and Installed a fresh new windows 10, can't find the brightness slider bar, so I check the Device Manager and this is what I saw
My CPU is Intel Core i5 12400F with ASUS H610M-E D4 mother-board, The IDs are:
PCI Device 1
PCI\VEN_8086&DEV_7AA4&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7AA4&CC_0C8000
PCI Device 2
PCI\VEN_8086&DEV_7ACC&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7ACC&CC_0C8000
RAID Controller
PCI\VEN_8086&DEV_467F&SUBSYS_86941043&REV_00
PCI\VEN_8086&DEV_467F&CC_010400
SM BUS Controller
PCI\VEN_8086&DEV_7AA3&SUBSYS_86941043&REV_11
PCI\VEN_8086&DEV_7AA3&CC_0C0500
UNKNOWN Device
ACPI\VEN_INTC&DEV_1056
ACPI\INTC1056
*INTC1056
You should get rid of the yellow bangs if you install the "Intel chipset driver" from
Couldnt find the driver for raid controller. thanks for that link
There seems to be a bug in Windows update catalog, hence no automatic installation
https://www.catalog.update.microsoft.com/Search.aspx?q=PCI%5CVEN_8086%26DEV_467F
Try the newest SATA driver from ASUS support.
Thank you! finally got rid off those yellow bangs.
