21611 Discussions
3V3 LVDS on MAX10
Vocabularix
Hello all,
I am designing a board containing the 10M04SAU169, and I will need several LVDS channels to communicate with the same board (there will be multiple boards containing this design in the system).
The MAX10 datasheet recommends a VCCIO voltage of 2.375 V < VCCIO < 2.625 V, but as the chip is single-supply, I would love to have a single 3V3 digital supply, as the board is very space constrained.
A piece of information that gave me hope is intel's LVDS guide : on page 18 and 28, no VCCIO voltage is shown on the LVDS schematics, indicating that maybe multiple voltage levels are acceptable.
A very important precision is that I will use AC-coupling in the LVDS links.
So, here are my questions :
  1. Can I use a 3,3V VCCIO in Bank 3, when using true LVDS Rx/Tx ?
  2. Could the emulated driver do it (in the other banks) ?
  3. Are the LVDS receivers self-biaised (do I need to "make" the common mode voltage on the receiver end) ?
I haven't tried to assign the pins in Quartus with the 3,3 V VCCIO, but someone in the forum (did and it looks like Quartus let them.
I'm looking for a datarate between 10 and 100 Mbps, 10b/8b balancing included.
AminT_Intel
The Vccio range for LVDS I/O Standard is from 2.375V to 2.625V. I will not recommend you to set it as 3.3V in this case as it can cause a permanent damage to your device.
Yes but do not mix up more than one IO standard in a single I/O bank. True LVDS is supported only in Bank 3 for Max10 devices.
No
No, LVDS receivers in Altera® devices do not have on-chip dc-biasing resistors. If you are AC-coupling between an LVDS transmitter and an LVDS receiver in an Altera device, use an external DC-biasing network at the receiver end to achieve the required common mode input voltage (VICM).
I hope this answer help in your FPGA design.
Thank you and stay safe!
Vocabularix
Thank you for your answers, I have a few more if you don't mind :
Is there a differential standard that I could use with 3,3V VCCIO ? Would I get a better data rate using Bank 3 IOs ?
I saw that the 10M08E144 Eval board powers its IOs with 3,3V, and uses its IOs in differential mode (100 ohms terminated). What is the "protocol" used ?
AminT_Intel
There is no differential standard with that can use with 3.3 V VCCIO in Max 10. You can refer to Max 10 I/O Standard table from this link on table 4 page 9
Thank you.
