Programmable Devices
Comunicados
21615 Discussões
A10 DSP Core Timing Error
Colaborador honorário II
1.503 Visualizações
Hi All,
I have a problem about Arria10 Chip MPDSP Core in my design. A path from register to MPDSP's ax[30] pin timing violate,
Then I used TimeQuest Timing Analyzer report this path and found that MPDSP's ax[30] pin setup time(uTsu)=2.955 ns.
Why this uTsu so long ?
The Timing analysis as post picture!
pofeng1885
shenh@innorise.cn
1 Responder
777 Visualizações
Can you locate the ax[30], or the path including launched from ax[30] in Technology map viewer?
You can do right-click on the cell of the Time Quest table, and select the Locate-path -> Technology map viewer.
I would like to know what resources is the path mapped to on the chip.
Mickycat
Responder
