Programmable Devices
21611 Discussions
ALTLVDS rx timing issue
kikoss
New Contributor II
Hello I have hold timing issue on the ALTLVDS RX  inside logic ..
I have an ALTLVDS RX ip confgiured like that
i get hold timing issues in timequest :
-0.019 u_tx_rx_wrapper|u_adc_controller|lvds_0|core|arch_inst|rx_channels[1].dpa_fifo.serdes_dpa_inst~rx_internal_reg u_tx_rx_wrapper|u_adc_controller|lvds_0|core|arch_inst|rx_channels[1].dpa_fifo.des[4].rxout_ufi~ufi_write_reg u_tx_rx_wrapper|u_tx_rx_pll|iopll_0_fclk0 u_tx_rx_wrapper|u_tx_rx_pll|iopll_0_loaden0
why its occur ?  its inside the altera IP ..
Thx
kikoss
Labels (2)
AqidAyman_Intel
May I know what is your input clock frequency?
kikoss
New Contributor II
Hello
the input clock frequency is 96Mhz
Thx
AqidAyman_Intel
Thank you for your confirmation. Does it come from the dedicated reference clock pin within the I/O bank?
Which device is this and you are using which version of Quartus Prime?
Aqid
AqidAyman_Intel
I wish to follow up. Do you have any update?
Aqid
kikoss
New Contributor II
Hello sorry for the delay
i was in vacancy
the quartus version is quartus prime 24.1
yes the clk is dedicated clock : BANK 2F  pin DD47
Thx
AqidAyman_Intel
Apologies not asking this earlier. Which device does this LVDS IP target?
kikoss
New Contributor II
Hello targeting the agilex7 f series : AGIB027R31B1E1V
AqidAyman_Intel
We have tried creating an example design with the parameters shown and saw no timing failures. The worst-case slack for the timing path listed was 2.853.
The large discrepancy between the slack we are seeing and the slack you are seeing is mostly likely due to you having a different clock relationship because their PLL clocks are configured incorrectly.
Ensure that the VCO frequency and the outclk frequency/phase shift/duty cycle settings on the external PLL driving the LVDS IP match the settings listed in the Clock Resource Summary in the LVDS IP.
Also, please ensure that the reference clock frequency on the PLL IP matches the Actual inclock frequency on the LVDS IP as the settings listed in the Clock Resource Summary tab may not be attainable with the wrong reference clock frequency.
Aqid
AqidAyman_Intel
If it’s not caused by incorrect clock configuration, other possible causes include using an outdated SDC due to using an old Quartus version (19.2 or older) or a placement/routing issue.
kikoss
New Contributor II
I dont see any issue on the design ... iam using : quartus prime 24.1 ..
any idea ?
kikoss
New Contributor II
I reduce my design to the minimum.
And seems that the issue occurs when we choose more than 2 channels
when running with 2 channels, no timing issue, when running with 3 channels, I get hold time issue ...
@AqidAyman_Intel  seems there its an altera issue ..
wait for help from @altera  ..
THX
kikoss
kikoss
New Contributor II
to be more precise : the issue occur when we have at least 3 channels and when the pll is external one  ..
AqidAyman_Intel
I will contact you through email since I need to share with you some of the snapshots.
Need your help to check the inbox.
Aqid
