21615 Discussions
Altera mm interconnect
Hi All,
Please anyone explain the functionality of altera_mm_interconnect. If you have any link for that please post .
Venkat
Hi Venkat,
I believed you are referring to Avalon Memory Map interface. Avalon interface is generally a bus interface used to connect multiple different design IP block together. You can find out more about Avalon Interface spec in
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf
spdl2001
(This message was posted on behalf of Intel Corporation)
The interconnect is generated by Qsys based on component parameter settings and connections between component interfaces. A better resource for learning about the interconnect would be the Quartus Prime Handbook.
