Programmable Devices
21595 Discusiones
Arria 10: Booting U-Boot from SD-Card does not configure FPGA
LFrin
Nuevo Colaborador I
10.447 Vistas
I have adapted the example for the Arria 10 SOCDK (Arria 10 SoC - Boot from SD Card) to the HAN-Pilot-Platform evaluation board from Terasic. I used the make_sdimage_p3.py script to generate the SD-Card image without linux binaries:
Partition 3: (format raw, type 0xA2) - u-boot-splx4.sfp
Partition 1: (format fat) - sdfs folder with - fit_spl_fpga.itb and u-boot.img
Partition 2: (format ext3) - empty
The SOC start-up seems to be ok, but the FPGA does not get configured:
Boot Console Arria 10 SOCBoot Console Arria 10 SOC
When i start the board without SD-Card, put it in, and then connect with the debugger and start the system with the Debugging U-Boot script. The system boots and the FPGA gets configured…
The start-up runs like from SD-Card, but the FPGA gets configured!
Some more informations:
  1. Quartus (22.3 Pro) compilation with “Early Release of HPS IO”
    1.1 Qsys EMIF with enabled “Early Release Mode”
  2. Convert .sof to .rbf with: quartus_cpf.exe --convert --hps -o bitstream_compression=off golden_top.sof golden_top.rbf
  3. Make fit_fpga_spl.itb with fit_fpga_spl.its in \u-boot-socfpga\board\altera\arria10-socdk
I recompiled U-Boot with #define DEBUG in include\configs\socfpga_common.h and found these error:
No configuration specified, trying default…
Found default configuration: ‘config-1’
FPGA: FPGA node count: 2
FPGA: fpga-periph-1
FPGA: fpga-core-1
FPGA: Start to program core bitstream …
FPGA: Data offset was found.
Can’t get ‘load’ property from FIT 0xffe24ec0, node: offset 248, name fpga-core-1 (FDT_ERR_NOTFOUND)
FPGA: No loadable was found.
FPGA: Using default DDR load address: 0x400 .
FPGA: External data: offset = 0x582d4, size = 0x1dcfb44.
blk_find_device: if_type=6, devnum=0: dwmmc0@ff808000.blk, 6, 0
Does anyone have any idea what the problem could be?
0 kudos
1 Solución
LFrin
Nuevo Colaborador I
9.795 Vistas
Hi @aikeu,
okay, now im sure: The Intel In-System Sources and Probes IP hinders the FPGA from starting normally after it has been correctly configured by SD-Card. Even the old Quartus-Project works without the ISSP-IP. Now it makes sense why the FPGA starts when a connection to the programmer is established via JTAG or similar.
My workaround will be, that i only use FPGA Firmware without the debugging features (ISSP, SignalTap, ...) on the SD-Card and when i need this debugging features i will start the HPS with the ARMD DS debugger.
Thanks for the help, my problem has been solved.
LFrin
Ver la solución en mensaje original publicado
22 Respuestas
LFrin
Nuevo Colaborador I
9.796 Vistas
Hi @aikeu,
LFrin
aikeu
Empleados
1.187 Vistas
Hi LFrin,
Glad that the issue has been resolved and thanks for sharing with the workaround method through your troubleshooting process.
I will close this thread for now and do consider open a new thread when there is further question.
Thanks agian.
Aik Eu
Responder
