21570 Discussions
Avalon mm pipeline bridge problem: multible write
CAlex
New Contributor II
Im using CycloneVsoc link lwh2f(32bit) ---> Avalon mm pipeline bridge(32bit) -----> MyIP core(8bit)
the following is the signal tap result:
When I ran alt_write_byte for one time in the timer IRQ.
Here is my verilog logic:
The port reset_wr here should be only one pulse signal when I wrote to the FPGA module.
The other problem is that writedata signal should be at 0b01---->0b11------->0b01------> loop
yet signal tap didnt catch the value.
It change from 01 to 00 for severial times.
Writedata[1] should be at 0 until I write.
Could you please help me with that?
Thank you.
Reguards
Alex
sstrell
You don't specify in your HDL what irq_en should be when write is low, so you've basically created a latch.
But I don't understand why in your Signal Tap capture writedata[1] does not match what is shown for writedata[7..0].  Are you sure you are tapping the correct signals or accidentally tapping a different writedata[1]?
CAlex
New Contributor II
Hi
irq_en is what I want to have,
reset_wr signal is not, I didnt expect 4 write signal when using alt_write_byte().
And yes, they are the same signal, which makes this case stranger.
sstrell
You do not want to have a latch, especially in an FPGA design.  They make it difficult to meet timing and can cause glitching.  That could be part of this problem depending on how irq_en is working with the rest of the design.
As for the weird writedata, I'd try removing and re-adding the signals in the .stp file or just create a brand new .stp in case the file is corrupt.
CAlex
New Contributor II
CAlex
New Contributor II
Hi,Sstrell
Since you mentioned on the latch problem,
do you mind sharing how you handle level-sensitive registers?
what Im trying to do is that irq_signal = irq_en & reset_assert.
irq_en should always be 1(if I write 1) until I write 0.
Thank you very much
sstrell
assign irq_signal = irq_en & reset_assert;
always @(posedge clk or negedge reset_n)
begin
     if (reset_n == 1'b0)
          irq_en <= 1'b0;
     else if (write)
          if (writedata[0])
               irq_en <= 1'b1;
          else
               irq_en <= 1'b0;
Your "write" signal is essentially a synchronous clock enable for the register and writedata[0] is a synchronous set.  You just have to cover both cases for it.  This should now synthesize correctly.
CAlex
New Contributor II
THANK YOU,
if you dont mind , I'll add that into my design.
CAlex
New Contributor II
And about the mult write problem, Ive created a new stp, but the problem still exist.
Have you ever meat this knid of wield problem before?
Tnak you again for your help.
