Programmable Devices
21588 Discussions
CYCLON V + DDR3 RAM reset/clock problems within BeMicro CV board
Hello everyone,
I am using the BeMicro CV Development Kit board which is based on a Cyclone V
Device 5CEFA2F23C8N. I am using Quartus II 64-Bit Version 13.1.0 Build 162
( problem also occurs with Version 14.0 ) and I am hanging in 2 problems:
1) sometimes after downloading the elf file: Note: The problem occurs always
if an external PLL is used:
Verifying 08000000 ( 0%)
Verify failed between address 0x8000000 and 0x800D71F
Leaving target processor paused
2) Reset problem: the reset does not work at all even though I followed the instructions
http://www.altera.com/support/kdb/solutions/rd07072011_71.html
The board will be dead if I press the reset button.
Enclosed, please find all the referece files. The myload.sh script in the flash directory
will load and start the test programm to the BeMicro CV board. I have testet 5 boards already
with the same result. Can anyone confirm that there is a problem in the CYCLONE V which is
clock/PLL related. If yes, is there a fix available ? or did I make a mistake in my qsys design?
Many thanks in advance
Reinhard
Start with my DDR3 example ...
http://www.alteraforum.com/forum/showthread.php?t=43992
The reset on the Hard IP core does not work correctly
--- Quote Start ---
Service Request#11062538
Cyclone V DDR3 UniPHY HMC Avalon-MM wait-request lockup after soft-reset
The uploaded zip file contains an example design for the BeMicro-CV device. While testing the DDR3 UniPHY controller, it was determined that pulsing soft-reset caused the Avalon-MM interface to lock-up. A Modelsim simulation was created that reproduces the problem, i.e., for some reason the DDR controller forces wait-request to be asserted after the soft-reset signal has been pulsed. The simulation shows that if the global-reset signal is pulsed, the testbench works fine.
Altera's Knowledgebase article
http://www.altera.com/support/kdb/solutions/rd05212013_358.html
has the comments that
"Altera strongly recommends using only soft_reset_n at all times.
Use global_reset_n only for Power on reset."
So, what is wrong with the Cyclone V Hard-memory controller?
The file altera_service_request.txt has details on how to synthesize and simulate the design example.
--- Quote End ---
This has yet to be resolved, but the example I have referred you to works fine.
Cheers,
Dave
Dave, thank you very much for your info but the "bemicro_cv_basic" does not realy help me. I will try to implement the fix from the Altera's Knowledgebase
--- Quote Start ---
--- Quote End ---
You didn't scroll down far enough in the other thread. Go all the way to the bottom and download bemicro_cv_examples.zip.
Cheers,
Dave
I followed the instructions from you but the problem still exists.
Enclosed, find the Qsys-file. I also figured out, that there is a
CYCLON V PLL bug in the first silicon version and it is also described
in the ALTERA Errata Sheet for Cyclone V Devices.
http://www.altera.com/literature/es/es_cyclone_v.pdf
All my BeMicro CV boards are equipped with known bad CYCLON V silicon.
Too bad for me. My question: Is there a solution available and not only a Workaround ?
Can I get my BeMicroCV boards replaced from ALTERA? Any Any idea is welcome.
Regards, Reinhard
--- Quote Start ---
--- Quote End ---
Weird. I ordered several when they first came out from Arrow USA and they have production silicon. I wonder if the European distributors had ES parts.
You could contact the distributor and see if they'll replace them ... or give you a discount :)
Cheers,
Dave
