21615 Discussions
Cyclone IV not detecting on blaster
Hi All,
I am working on an open source project using which is using cyclone IV EP4CE22F.
Everything was working as per planned when all of a sudden my kit stops identifying on my laptop through USB Blaster. The kist is working as it is getting heated a little whereas the LEDs are not working which were linked to the code (I suspect the code got faulty but to update it I need blaster to work hence, a problem)
IDK what happened which caused it this error. Anyone, please help!
Thanks in advance
--- Quote Start ---
Hi All,
Thanks in advance
--- Quote End ---
1.Is USB Blaster detectable by host machine (device manager->UBS controller->Alter USB-Blaster)?
If NO.
USB Blaster is damaged may be because of common ground issues
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Hi Anand,
First of all thanks for answering and yes, the USB blaster is being detected by my host machine and I have tried two different Blasters, both of which are being detected by the host machine whereas the FPGA is not beign recognised.
Nipun Sharma
Hi
--- Quote Start ---
Hi Anand,
Nipun Sharma
--- Quote End ---
Which version of quartus is installed in laptop?
Anand Raj Shankar
I am using 2 machines simultaneously on which I have Quartus 14.1 and on one I have Quartus prime 17.1 lite edition.
I checked the test points on my kit which are giving fine results even the FPGA is heating up a bit like it used to when it was working.
Is it not detectable on both the version now?
Anand Raj Shankar
hello sir,
No sir it is not
It was being detected earlier but now its not on both the versions.
no sir,
It was being detected earlier but now it is not on both the versions
You can check the board power components and regulators on board.
FPGA may be damaged.
Anand Raj Shankar
