21602 Discussions
DE1-SoC problem with tree please HELP!!
I’m trying to configure a qsys system with hps and vga control to see the Linux environment and create a c program that can obtain the memory mapped signal and print on the vga.
The steps that I did are:
-Create a golden top and qsys system
-Create a rbf with convert file formats(no compression)
-Download de Ubuntu from altera and prepare de sd with that image
-Download de soc_system_board_info.xml and hps_common_board_info.xml files from https://releases.rocketboards.org/release/2014.06/gsrd/ghrd/
-Create a dtb in two steps:
$ sopc2dts -i sistema.sopcinfo -b soc_system_board_info.xml -b hps_common_board_info.xml -o socfp ga.dts --bridge-removal all --clocks
$ dtc -I dts -O dtb -o socfpga.dtb -f socfpga.dts
There are some errors:
$ sopc2dts -i sistema.sopcinfo -b soc_system_board_info.xml -b hps_common_board_info.xml -o socfpga.dts --bridge-remova l all --clocks
Component alt_vip_itc_0 of class alt_vip_itc is unknown
Component pll_0 of class altera_pll is unknown
Component pll_6553600 of class altera_pll is unknown
Component reset_controller_0 of class altera_reset_controller is unknown
Component reset_controller_1 of class altera_reset_controller is unknown
Component video_pll_0 of class altera_up_avalon_video_pll is unknown
MasterIF sopc2dts.lib.components.Interface@76fb509a slaveIF null
ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "pll_0" ERROR (phandle_references): Reference to non-existent node or label "led_pio" ERROR (phandle_references): Reference to non-existent node or label "led_pio" ERROR (phandle_references): Reference to non-existent node or label "led_pio" ERROR (phandle_references): Reference to non-existent node or label "led_pio" Warning: Input tree has errors, output forced
-Remplace the socfpga.dtb and soc_system.rbf from sd for my files.
The MSEL is all to 000000 and I plug in the sd and the system start to kernel but has an error
https://alteraforum.com/forum/attachment.php?attachmentid=13839&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=13840&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=13841&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=13842&stc=1
Any idea? Tanks!,
Juan.
Hello, for the VIP IP in the FPGA, you will need to add to the device tree manually (as far as I know, the device tree generator does not recognize the VIP IP). To obtain the VIP device tree declaration, you can use the device tree file that is included in the DE1-SoC MTL2 package.
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=204&no=930&partno=4
I've attached the relevant dtsi file here - you can modify or merge with your own dts file
Thank!.. but I have a VIP declaration in device tree
--- Quote Start ---
--- Quote End ---
alt_vip_vfr_0: vip@0x100000000 { compatible = "ALTR,vip-frame-reader-14.0", "ALTR,vip-frame-reader-9.1"; reg = <0x00000001 0x00000000 0x00000080>; clocks = <&video_pll_0 &pll_0>; clock-names = "clock_reset", "clock_master"; max-width = <1024>; /* MAX_IMAGE_WIDTH type NUMBER */ max-height = <768>; /* MAX_IMAGE_HEIGHT type NUMBER */ bits-per-color = <8>; /* BITS_PER_PIXEL_PER_COLOR_PLANE type NUMBER */ colors-per-beat = <4>; /* NUMBER_OF_CHANNELS_IN_PARALLEL type NUMBER */ beats-per-pixel = <1>; /* NUMBER_OF_CHANNELS_IN_SEQUENCE type NUMBER */ mem-word-width = <128>; /* MEM_PORT_WIDTH type NUMBER */ }; //end vip@0x100000000 (alt_vip_vfr_0) }; //end bridge@0xff200000 (hps_0_bridges)
I'm not worried for the error messages because som of them not have a connection with the hps. There are something wrong in other part of the code.
I add a *dtb file in txt format generated by the commandsopc2dts -i sistema.sopcinfo -b soc_system_board_info.xml -b hps_common_board_info.xml -o socfpga.dts --bridge-remova l all --clocks. You can check that is there a VIP declaration.
Hi, I'm worried about this. Do I have to recompile linux? Is this mandatory?
--- Quote Start ---
--- Quote End ---
I think the situation is this:
When you created an IP component in qsys his definition is in your_qsys.sopcinfo but not is in soc_system_board_info.xml and hps_common_board_info.xml so the sopc2dts command can't create a component and the device tree is uncomplete.
Is this true? editting the xml files mut solve the problem.
