Programmable Devices
21595 Discussions
DE10 Lite setting pins from VErilog RTL
YigalB1
In my design, the GPIOs need to be used to connect to external host (Raspberry PI (aka RPI) in this case).
The GPIOs connector of the DE10 lite will be connected to the RPI connector.
Some are inputs, some are outputs.
I prefer to set the pins assignment from the Verilog file, to allow easier maintenance of the project over time.
Gemini AI suggested to use:
(* location = "PIN_AA13" *) assign gpio_out1 = gpio_out1_int;
Yet the compiler reports:
Warning (10335): Unrecognized synthesis attribute "location" at ../Verilog/MAC_proj.v(142)
Gemini claims I might not be using Quartus Synthesis tool.
Could it be?
How can I check and set it correctly?
sstrell
Just edit the top-level.  And you need to give unique names to inputs vs. outputs (GPIO_IN vs. GPIO_OUT perhaps).
sstrell
I don't think that's a valid synthesis attribute.  You have to store location assignments in the .qsf.  This is a list of synthesis attributes: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/hdl/vlog/vlog_file_dir.htm
RichardTanSY_Altera
Pin assignment is not possible through RTL.
You need to use 'set_location_assignment' in the .qsf file.
Check the User Guide below for further details.
https://www.intel.com/content/www/us/en/docs/programmable/683432/21-3/tcl_pkg_project_ver_7.0_cmd_set_location_assignment.html
Alternatively, you could use the Pin Planner tool by go to Assignments > Pin Planner.
Richard Tan
RichardTanSY_Altera
Dropping a note to ask if my last reply was helpful to you.
Do you need any further assistance from my side?
Richard Tan
YigalB1
I think there is a way to control pinout from the RTL source file.
There is a "golden top" within  "CD-ROM" download files. All the pins are listed, I assume these are keywords that guide the pin planner.
The problem I faced was with definition of IOs: GPIO[35:0] was defined  as INOUT.
When trying to define part of it as Input, and part as output (i.e input GPIO[7:0]; output GPIO[15:8];) the compiler reported error fo double definition of GPIO.
RichardTanSY_Altera
Could you share the design for the golden top?
You mentioned that the pin is assigned—could you check if it’s assigned through the .qsf file or the RTL? If it’s assigned in the RTL, what does it look like?
Also, what is the exact error message shown by the compiler?
Please paste the error message or provide a screenshot for reference
Richard Tan
YigalB1
When compiling this:
input  [7:0]   GPIO,
input   [15:8]  GPIO
The error is:
Error (10134): Verilog HDL Module Declaration error at MAC_proj.v(37): port "GPIO" is declared more than once
About the pins assignment:
You have a good point. I assumed it was done due to naming, yet now I can see the QSF has these names inside.
Here is the golden top:
//  This code is generated by Terasic System Builder
module DE10_LITE_Golden_Top(
//////////// CLOCK //////////
input           ADC_CLK_10,
input           MAX10_CLK1_50,
input           MAX10_CLK2_50,
//////////// SDRAM //////////
output     [12:0] DRAM_ADDR,
output      [1:0] DRAM_BA,
output           DRAM_CAS_N,
output           DRAM_CKE,
output           DRAM_CLK,
output           DRAM_CS_N,
inout     [15:0] DRAM_DQ,
output           DRAM_LDQM,
output           DRAM_RAS_N,
output           DRAM_UDQM,
output           DRAM_WE_N,
//////////// SEG7 //////////
output      [7:0] HEX0,
output      [7:0] HEX1,
output      [7:0] HEX2,
output      [7:0] HEX3,
output      [7:0] HEX4,
output      [7:0] HEX5,
//////////// KEY //////////
input      [1:0] KEY,
//////////// LED //////////
output      [9:0] LEDR,
//////////// SW //////////
input      [9:0] SW,
//////////// VGA //////////
output      [3:0] VGA_B,
output      [3:0] VGA_G,
output           VGA_HS,
output      [3:0] VGA_R,
output           VGA_VS,
//////////// Accelerometer //////////
output           GSENSOR_CS_N,
input      [2:1] GSENSOR_INT,
output           GSENSOR_SCLK,
inout           GSENSOR_SDI,
inout           GSENSOR_SDO,
//////////// Arduino //////////
inout     [15:0] ARDUINO_IO,
inout           ARDUINO_RESET_N,
//////////// GPIO, GPIO connect to GPIO Default //////////
inout     [35:0] GPIO
//  REG/WIRE declarations
//  Structural coding
endmodule
sstrell
YigalB1
True, yet in this case I need to modify accordingly the qsf file naming, to maintain the IO mapping.
RichardTanSY_Altera
I believe all your inquiries has been answered.
Do you have any further question?
Richard Tan
YigalB1
I think I am all set. Thank you for the good support.
RichardTanSY_Altera
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you and have a great day!
Richard Tan
