Programmable Devices
21611 Discussions
Decrease configuration time
Hi all, I have a Cyclone III LS set for Standard AS configuration (MSEL[3:0] = 0010) using an EPCS64 to store the config file.
I'd rather not make a PCB change, so the MSEL pins will probably have to stay as they are.
I'm looking to make the FPGA configuration time as short as I possibly can.
I enabled "Generate compressed bitstreams" in Device and Pin Options. I also turned on compression when converting the .sof to a .jic.
Is there anything else I can do to minimize the time?
Thanks!
Use 40 MHz Internal Oscillator.
