Programmable Devices
21569 Discussões
Delay in SPI-to-Avalon-MM IP Response After MAX10 Reset
chrisssynco
Novato
436 Visualizações
Hello everyone,
I’m using the SPI-to-Avalon-MM IP to enable communication between an external microcontroller (MSP430) and a MAX10 FPGA (MAX10M50DAF256CG). In my setup, the microcontroller acts as the SPI master, and the FPGA is the slave.
The microcontroller also controls a GPIO line connected to a load switch, allowing it to power the MAX10 on or off. The FPGA receives a 26 MHz external oscillator input, which feeds into a PLL. The PLL’s lock signal is used to generate a system reset.
Here’s the behavior I’m observing: even after the PLL lock signal asserts and the system leaves reset (measured by routing the lock signal to an external FPGA pin and timing from the moment CONF_DONE goes high), it still takes around 9 ms before the FPGA and the SPI-to-Avalon-MM IP start responding to SPI messages from the microcontroller.
My questions are:
  • What could be causing this post-reset delay?
  • Is there a defined startup time for the FPGA and IP to begin responding?
  • I haven’t found documentation on this—are there any relevant resources?
Thanks in advance for your help.
Etiquetas (3)
1 Solução
khtan
Funcionário
203 Visualizações
Hi chrissynco,
Sorry for the delay in responding to the thread, didn't notice about the reply posting failure due to login timeout, had to retype my reply.
As for your question I did a search around our database, what I could say is there is a no hard defined startup time for the FPGA and IP to begin responding, it could be a combination of different factors.
From the behavior that you observed :
CONF_DONE goes high
PLL lock asserts (system leaves reset?)
9ms respond from SPI core to SPI traffic
CONF_DONE goes high indicates FPGA configuration received and then finishes initialization then only enter user mode. From the documentation I saw from Agilex/Stratix 10, recommendation is to hold logic in reset until all fabric is in user mode.
Note: The entire device does not enter user mode simultaneously. Intel recommends that you follow the Including the Reset Release Intel FPGA IP in Your Design to hold your application logic in the reset state until the entire FPGA fabric is in user mode.
https://www.intel.com/content/www/us/en/docs/programmable/683762/22-1/conf-done-and-init-done.html
https://www.intel.com/content/www/us/en/docs/programmable/683539/20-4/using-the-reset-release.html
For MAX10 there is no INIT_DONE but it have internal tCD2UM with min-max wait time (in uS). https://www.intel.com/content/www/us/en/docs/programmable/683794/current/internal-configuration-timing-parameter.html
Maybe do look into the reset release mechanism is it after FPGA enters user mode.
The other area to look at probably at the SPI Core The SPI core logic is synchronous to the clock input provided by the Avalon-MM interface. It will not able to response just by SCLK alone until the Avalon clock is running and reset de-asserted. See whether is there any gating item that introduces delay in this area.
https://www.intel.com/content/www/us/en/docs/programmable/683094/22-1/serial-port-interface-spi.html
How about the power rails that is controlled by the load switch from the microprocessor, does the voltage instantly stable or does it ramp up over few ms?
Some additional documentation
Max10 FPGA configuration user guide
https://www.intel.com/content/www/us/en/docs/programmable/683865/current/fpga-configuration-overview.html
Kian
Ver solução na publicação original
1 Responder
khtan
Funcionário
204 Visualizações
Hi chrissynco,
CONF_DONE goes high
Kian
Responder
