Programmable Devices
21615 Discussions
Devide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare.
When I try with "*" (multiply) or "+" (add), it is ok.
I don't know this error, Please help me.
Thank you very much.
two methods:
1. result <= (not result) + 1;
2. (probably easiest) result <= -result; (this will probably result in the same hardware as above when synthesised).
And if you need more information about how to represent negative numbers in binary, this page from wikipedia (http://en.wikipedia.org/wiki/two's_complement) should answer your questions.
--- Quote Start ---
two methods:
--- Quote End ---
Oh. It's so easy but I don't find out. Thank Tricky very much.
Thanks Daixiwen for your usefull information.
Dear Tricky and Daixiwen
Could you check this code for me?
When I simulate by waveforms vector of Quartus, at Result_out, the final result is true but I have a lot of result
Ex: (-30)x(-6) = 180 but I saw, they have 16, 148, 180. (I attached this waveforms in this message)
I don't know this value.
Thanks before.
library IEEE; USE IEEE.std_logic_1164.all; USE IEEE.numeric_std.all; Entity Multvhdl is Port ( A,B : In Signed(15 downto 0); --A*B Result_out : Out Signed(31 downto 0); CLK : In std_logic); end Multvhdl; Architecture structural of Multvhdl is Signal Multiplicant,Multiplier : Signed(15 downto 0); Signal Result : Signed(31 downto 0); Signal CNT : unSigned(3 downto 0); Signal Sign : unSigned(1 downto 0); Begin Process(clk) Begin if clk='1' and clk'event then cnt<=cnt+"1"; sign<="0" & (A(15)xor B(15)); --Check sign of A and B if cnt="0000" then Multiplicant<= ABS (A); Multiplier<= ABS (B); elsif cnt="0001" then Result<=Multiplicant*Multiplier; elsif cnt="0010" then if sign = "00" then Result_out<=result; elsif sign = "01" then Result_out<= -result; end if; cnt<="0000"; end if; end if; end process; end structural;
Alt first sight, the result_out waveform seems not to fit the above design (it may be still possible under specific conditions). result_out is a registered signal, clocked by the 100 MHz clock, but it changes shortly before the next rising edge, usually causing a setup violation for the following logic. Without knowing the previous states of all signals, and the timing constraints in effect, I can only guess about the reason for this behaviour.
I also don't understand the purpose of the strange method to do a signed multiplication. The ABS() function is by the way causing an overflow for the most negative number -32768 (0x8000), which hasn't a corresponding positive value.
P.S.: I see, that a similar negation method has been used previously in the thread. It may be a workaround for algorithms, that aren't avaliable for negative numbers for some reason. But multiply is.
Dear FvM
I want to implement Multiplication command in VHDL. Because Modelsim does not support for LPM library. And when I use multiply command directly, the result's not true with the negative number.
In this method, I multiply two positive number, and use sign<=A(15)xor B(15); to check the sign of A and B.
If sign=0 => the result's positive. else the result's negative.
When I simulate with the waveforms, it appear strange value. I did not understand it.
Do you have other idea for this?
The output is not valid until CNT is 2 anyway, so until then all signals are rubbish.
--- Quote Start ---
Dear FvM
--- Quote End ---
You can precompile most libraries in Modelsim.
Usually altera_modelsim will have these lpm/altera_mf libraries ready from installation.
Otherwise you can precompile as follows:
go to modelsim => compile => set library name to lpm => navigate to altera folders that contain 220pack.vhd/220model.vhd. select them and compile.
--- Quote Start ---
--- Quote End ---
Thank Tricky.
I had check this many times but I still did not know why the output have a lot of value. When I use this utility as a component for my project, the waveforms not nice.
When i multiply -400x8, the final value still ok. but there are more than 10 strange value before the final value. (I attached waveform in this message)
I don't know how to correct it.
--- Quote Start ---
--- Quote End ---
Thank Kaz
I had done that a lot of time but it still error (Modelsim said, they do not found lpm library). I will make it step by step and send it to you, i hope you check it for me. Thanks again
--- Quote Start ---
--- Quote End ---
Valid result or not, a registered output can't change arbitrarily. Or the design's timing is completely broken.
--- Quote Start ---
--- Quote End ---
Last time I used it, all LPM libraries simulated fine in ModelSim. Sorry, I also don't understand about the negative number problems. At least, I wasn't aware of it (since Quartus V2.0).
--- Quote Start ---
--- Quote End ---
Really?
LPM library took me a lot of time. I use Modelsim plus 5.7d and Quartus 7.2
Could you help me step by step with it?
All Quartus specific libraries (LPM and device specific) have been installed during initial ModelSim installation (some ModelSimDE6.1 or 6,2 version). Unlike when simulating Verilog, I don't remember missing library issues with VHDL designs. But I don't have ModelSim installed on my computer now and can't check these problems.
An additional remark related to your previously posted waveform. You didn't ever mention a device family. The timing could be explained if either belonging to a very slow logic family, or if the synthesis options in effect would allow to move an output register.
--- Quote Start ---
--- Quote End ---
I don't know, why menu compile of my Modelsim software is not active. I can not choose it.
I add 220pack.vhd/220model.vhd to my project and compile => not ok
I can not make new library from "a new library and a logical mapping to it" or "a map to an existing library" to folder that contain 220pack.vhd/220model.vhd file.
This is my video:
Add 220pack.vhd/220model.vhd to project and compile them: http://www.mediafire.com/?44i1sj5bgnkduty
Can not make new library: http://www.mediafire.com/?53zp5xyrpd2zdjk
Can not make new library: http://www.mediafire.com/?krc4l1g5u5uyayj
Could you check it for me.
Thank alot
--- Quote Start ---
--- Quote End ---
I'm sorry when i forgot mention a device family.
I use DE2-70 (Cyclone II) - EP2C70F896C6
--- Quote Start ---
--- Quote End ---
Hi Kaz
How's about altera_modelsim?
It's a single software or built-in with quartus software?
Why I don't see it in my computer?
Thanks everybody very much. I had already done Modelsim - VHDL. If add 220pack.vhd/220model.vhd in to project and compile it to folder lpm you can work with lpm library in modelsim. Thanks everybody again.
