Programmable Devices
20737 Discussions
Error: No EPCS layout data - looking for section [EPCS-9D6017]
RWeiz
Error: Unable to use EPCS device
Error: Error code: 8 for command: nios2-flash-programmer "D:/ANSER_Proj/Altera_FPGA/TIJ_Engine_proj/software/TIJ_bsp/flash/DE10_NANO_TIJ_Engine_epcs_flash_controller_0.flash" --base=0x41000 --epcs --sidp=0x42138 --id=0x42138 --timestamp=1555660140 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --verbose
JohnT_Intel
Hi, May I know which Quartus version and EPCS device are you using? Are you using DE1-SOC (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=205&No=836&PartNo=1) board?
RWeiz
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=Taiwan&No=1047
RWeiz
Quartus (Quartus Prime 18.1) Lite Edition
JohnT_Intel
Hi, Could you confirm which board version are you using as I suspect that you are using Rev A or B which is utilizing EPCS128 flash device? Please refer to https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1046&PartNo=4 on how to check the board version
RWeiz
EPCS64
JohnT_Intel
Hi, That is what you set but I don't think EPCS64 is used on the board. Please confirm your board version.
RWeiz
[EPCS-010216] # EPCS64N
sector_size = 65536
sector_count = 128
[EPCS-014017] # EPCS64N
sector_size = 65536
sector_count = 128
[EPCS-9D6017] # EPCS64N
sector_size = 65536
sector_count = 128
[EPCS-012018] # EPCS128
sector_size = 262144
sector_count = 64
[EPCS-FF] # EPCS64N
sector_size = 65536
sector_count = 128
RWeiz
Rev.C
RWeiz
我的JIC可以燒錄成功​
 configuration device: EPCS64
我的設備,版本
RWeiz
JohnT_Intel
Hi, Do you follow the user guide from Terasic chapter 8.5?
RWeiz
​chapter 8.5 我有跟著做​
RWeiz
JohnT_Intel
May I know if you are able to use older version of Quartus which is 14.1? I would like to confirm if this is happening only in latest Quartus version only.
RWeiz
RWeiz
JohnT_Intel
Hi, Could you try the method mention in https://www.intel.com/content/www/us/en/programmable/documentation/iga1446487888057.html#jrn1481229919317 (Chapter Nios II Processor Booting from EPCQ Flash)? You will need to change the device to EPCS and Configuration mode to Active Serial Mode.
RWeiz
RWeiz
JohnT_Intel
The setting looks good to me.
