Programmable Devices
Comunicados
21618 Discussões
Error: No EPCS layout data - looking for section [EPCS-9D6017]
RWeiz
Principiante
6.336 Visualizações
Error: Unable to use EPCS device
Error: Error code: 8 for command: nios2-flash-programmer "D:/ANSER_Proj/Altera_FPGA/TIJ_Engine_proj/software/TIJ_bsp/flash/DE10_NANO_TIJ_Engine_epcs_flash_controller_0.flash" --base=0x41000 --epcs --sidp=0x42138 --id=0x42138 --timestamp=1555660140 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --verbose
20 Respostas
JohnT_Intel
Funcionário
5.366 Visualizações
Hi, May I know which Quartus version and EPCS device are you using? Are you using DE1-SOC (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=205&No=836&PartNo=1) board?
RWeiz
Principiante
5.366 Visualizações
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=Taiwan&No=1047
RWeiz
Principiante
5.366 Visualizações
Quartus (Quartus Prime 18.1) Lite Edition
JohnT_Intel
Funcionário
5.366 Visualizações
Hi, Could you confirm which board version are you using as I suspect that you are using Rev A or B which is utilizing EPCS128 flash device? Please refer to https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1046&PartNo=4 on how to check the board version
RWeiz
Principiante
5.366 Visualizações
EPCS64
JohnT_Intel
Funcionário
5.366 Visualizações
Hi, That is what you set but I don't think EPCS64 is used on the board. Please confirm your board version.
RWeiz
Principiante
5.366 Visualizações
[EPCS-010216] # EPCS64N
sector_size = 65536
sector_count = 128
[EPCS-014017] # EPCS64N
sector_size = 65536
sector_count = 128
[EPCS-9D6017] # EPCS64N
sector_size = 65536
sector_count = 128
[EPCS-012018] # EPCS128
sector_size = 262144
sector_count = 64
[EPCS-FF] # EPCS64N
sector_size = 65536
sector_count = 128
RWeiz
Principiante
5.366 Visualizações
Rev.C
RWeiz
Principiante
5.366 Visualizações
我的JIC可以燒錄成功​
 configuration device: EPCS64
我的設備,版本
RWeiz
Principiante
5.366 Visualizações
JohnT_Intel
Funcionário
5.366 Visualizações
Hi, Do you follow the user guide from Terasic chapter 8.5?
RWeiz
Principiante
5.366 Visualizações
​chapter 8.5 我有跟著做​
RWeiz
Principiante
5.366 Visualizações
JohnT_Intel
Funcionário
5.366 Visualizações
May I know if you are able to use older version of Quartus which is 14.1? I would like to confirm if this is happening only in latest Quartus version only.
RWeiz
Principiante
5.366 Visualizações
RWeiz
Principiante
5.366 Visualizações
JohnT_Intel
Funcionário
5.366 Visualizações
Hi, Could you try the method mention in https://www.intel.com/content/www/us/en/programmable/documentation/iga1446487888057.html#jrn1481229919317 (Chapter Nios II Processor Booting from EPCQ Flash)? You will need to change the device to EPCS and Configuration mode to Active Serial Mode.
RWeiz
Principiante
5.366 Visualizações
RWeiz
Principiante
5.366 Visualizações
JohnT_Intel
Funcionário
5.060 Visualizações
The setting looks good to me.
Responder
