Hi all,
I have a problem to run quartus on my linux, when I simply run it, I have a message like this :./quartus
Abandon
So I modified a little the run script to see where is the problem : quartus
Failed to start Core Services: Failed to launch rpcss
After this I decide to see the rpcss program : ./rpcss
Failed to start Core Services: Failed to launch rpcss.
03/04 18:07:52 ->
Registry server is currently unavailable (0)
Does someone have an idea on my problem ? Thanks a lot...
I installed quartus 9.1 on an upto date FC12 system, and it gives me a similar issue on starting quartus
$ which quartus /tools/altera/9.1/quartus/bin/quartus $ quartus 19/05 12:41:53 [# 1] -> RPCSS ServiceMain failed with 1702 (000006a6) The binding handle is invalid. Segmentation fault (core dumped) The quartus logo appears for few seconds and then it dies. Any ideas which package I need to remove. It seems like RPCSS is a windows issue on googling, is this some thing related to wine. I checked the list of processes using ps, no command name with rpcss. The closest I found are root 1188 2 0 11:40 ? 00:00:00 [rpciod/0] root 1189 2 0 11:40 ? 00:00:00 [rpciod/1] Any ideas?- Mark as New
i am running web edition 9.1sp2 on FC12 without problems (after removing 2 .so in the Quartus install as mentioned in some other threads).
are you using web or subscription edition? if subscription try running mwcleanup (also in $QUARTUS_ROOTDIR/bin).- Mark as New
I forgot to paste the solution, now that I got this problem on a new machine, I am posting it here. The Fedora linux distro FC13 (11,12 too) by default puts machine name (abcd here) in /etc/hosts
as first line 127.0.0.1 abcd.domain.com abcd localhost.localdomain localhost The line should be either 127.0.0.1 localhost.localdomain localhost or the line commented out altogether to get rid of this error. You all need machine ip in there. 192.168.1.xx abcd.domain.com abcd- Mark as New
mine looks like your modified version also, i can't remember if i changed it from default
$ cat /etc/hosts
::1 localhost6.localdomain6 localhost6
Having the same problem; prior to it, 9.1 ran fine on this machine for close to 8 months.
FC12, x64. Ran mwcleanup, didn't help. Any other ideas?- Mark as New
it was working fine and then just stopped?
must have been a change in a yum update. did you take a look at your /etc/hosts as mentioned above?- Mark as New
Yep, /etc/hosts look fine. Probably a yum update caused it. I wish I knew how to debug this - MainWin documentation is scarce, and Altera will probably wave it off, since they only support RHEL...
BTW, happens both on 9.1 and 9.1.2; 10.0 and 10.0.1 run fine.- Mark as New
--- Quote Start --- I forgot to paste the solution, now that I got this problem on a new machine, I am posting it here. The Fedora linux distro FC13 (11,12 too) by default puts machine name (abcd here) in /etc/hosts as first line 127.0.0.1 abcd.domain.com abcd localhost.localdomain localhost The line should be either 127.0.0.1 localhost.localdomain localhost or the line commented out altogether to get rid of this error. You all need machine ip in there. 192.168.1.xx abcd.domain.com abcd --- Quote End --- Thank you that solved my problem :) Details: I'm running Ubuntu 10.10, and installed Altera NiosII IDE and Quartus (both version 9.0) my /etc/hosts content was (when Quarts was giving "Segmentation fault"): 192.168.0.57 MirDesktop# Added by NetworkManager 127.0.0.1 localhost.localdomain localhost ::1 MirDesktop localhost6.localdomain6 localhost6 127.0.1.1 MirDesktop # The following lines are desirable for IPv6 capable hosts ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters When commenting row 3 and 4, everything works fine, my /etc/hosts looks now: 192.168.0.57 MirDesktop# Added by NetworkManager 127.0.0.1 localhost.localdomain localhost #::1 MirDesktop localhost6.localdomain6 localhost6 #127.0.1.1 MirDesktop # The following lines are desirable for IPv6 capable hosts ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters Hope this will help someone :) Thank you
