Programmable Devices
21615 Discussions
HLS run Quartus compile FAILED.
My HLS quartus complies fails with following error, although synthesis is successfully.
Info: Running Quartus Prime Synthesis
Info: Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition
Info: Processing started: Mon Jul 23 09:02:12 2018
Info: Command: quartus_syn --read_settings_files=off --write_settings_files=off quartus_compile -c quartus_compile
Info: Using INI file /home/tempuser11/counter/counterDUT1.prj/quartus/quartus.ini
Info: qis_default_flow_script.tcl version:# 1
Info: Initializing Synthesis...
Info: Project = "quartus_compile"
Info: Revision = "quartus_compile"
Info: Analyzing source files
Error (19286): No license for family Arria 10
Error: Flow failed: ERROR: Current design not found
Error: Quartus Prime Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 868 megabytes
Error: Processing ended: Mon Jul 23 09:02:12 2018
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus Prime Full Compilation was unsuccessful. 4 errors, 0 warnings
Error: Flow compile (for project /home/tempuser11/counter/counterDUT1.prj/quartus/quartus_compile) was not successful
Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script /D/intelFPGA_pro/17.1/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 11 errors, 0 warnings
Error: Peak virtual memory: 696 megabytes
Error: Processing ended: Mon Jul 23 09:02:14 2018
Error: Elapsed time: 00:00:14
Error: Total CPU time (on all processors): 00:00:05
--- Quote Start ---
My HLS Quartus complies fails with the following error, although synthesis is successful.
--- Quote End ---
Can you elaborate more on the steps or attach complete log?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Please find the attached log.
It looks like you do not have license for compiling for Arria 10 FPGA. Either check what license you have or use another device which you have license for.
