My HLS quartus complies fails with following error, although synthesis is successfully.
Info: Running Quartus Prime Synthesis Info: Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition Info: Processing started: Mon Jul 23 09:02:12 2018 Info: Command: quartus_syn --read_settings_files=off --write_settings_files=off quartus_compile -c quartus_compile Info: Using INI file /home/tempuser11/counter/counterDUT1.prj/quartus/quartus.ini Info: qis_default_flow_script.tcl version:# 1 Info: Initializing Synthesis... Info: Project = "quartus_compile" Info: Revision = "quartus_compile" Info: Analyzing source files Error (19286): No license for family Arria 10 Error: Flow failed: ERROR: Current design not found Error: Quartus Prime Synthesis was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 868 megabytes Error: Processing ended: Mon Jul 23 09:02:12 2018 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:01 Error (293001): Quartus Prime Full Compilation was unsuccessful. 4 errors, 0 warnings Error: Flow compile (for project /home/tempuser11/counter/counterDUT1.prj/quartus/quartus_compile) was not successful Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last. Error (23031): Evaluation of Tcl script /D/intelFPGA_pro/17.1/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 11 errors, 0 warnings Error: Peak virtual memory: 696 megabytes Error: Processing ended: Mon Jul 23 09:02:14 2018 Error: Elapsed time: 00:00:14 Error: Total CPU time (on all processors): 00:00:05Link Copied
--- Quote Start --- My HLS Quartus complies fails with the following error, although synthesis is successful. --- Quote End --- Can you elaborate more on the steps or attach complete log? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
It looks like you do not have license for compiling for Arria 10 FPGA. Either check what license you have or use another device which you have license for.
