I am working on a design with bidirectional interfaces having an io count of more than 2000. I want to fit the design on a device and check its timings. But the max available pin count is hardly 1000.
I cant use the virtual pin assignment as it is ignored for bidirectional pins. Is there anyother way to fit the design ? Thanks链接已复制
10 回复数
why do you have more than 2000 bidirections IOs? how do you expect these to work on a real chip? Bidirs internally are converted to muxes. Bidirectional signals should really only be connected to a pin.
If they were coded as separate ins and outs (as they will end up as eventually anyway) then you could easily use virtual pins.Yes i know...but i am doing a module level synthesis. This module has some huge combo logic and i want to be aware of the timing so that i dont have probs at the top.
Now coming back to interfaces , these wont be in the port list in the top, so i just want to do a module level synthesis as i doubt that this module might cause timing probs when i integrate it. So can you help me as to what i can do regarding this? Thanks :)do you know SignalTapII?
you can watch signals inside of FPGA via JTAG this document http://www.akiron.com/fpga/ (choose BaseProjectInVerilog) may help you to signaltapIInow that i think about it, this still may not work. anyhow...
1. port map the bidir bus to an HDL file that defines the bidir I/O but nothing else 2. run Analysis and Elaboration 3. find the bidir dummy module in the Hiearchy window 4. right click and create a new parition 5. in Assignments > Design Partitions change the Netlist Type for the dummy partition to Empty
