21602 Discussions
How to connect one PCIe Reference clock to TWO GXB banks in Arial10?
xytech
Hi there,
We use 10AX057H3F34E2SG, one PCIe x8 GEN3.0 link connect to PC's PCIe node. PC will provide one PCIe Reference clock 100MHZ.
Since each GXB bank contains 6 transceiver-channels, TWO GXB Banks will be used, such as 6+2 or 4+4 channels.
Question: How could we connect one PCIe REF clock to TWO GXB Banks's dedicated REFCLK pins? Or is it OK to connect PCIe REF clock to either one of the 2 GXB Banks ?
and where could we found this information on Intel's Documentation?
Thanks!
Nathan_R_Intel
For PCIe Gen3x8, you will be using 8 transceiver channels. However, you only need one PCIe reference clock. The reference clock will be connected to 1xATX PLL and 8 CDR of 8 receiver channels through internal clock networks (within FPGA). Quartus Prime will handle the internal clock connection. All user need to do is specify the Pin where the PCIe REFCLK is to be connected. Regards, Nathan
xytech
xytech
Nathan_R_Intel
xytech
Hi Nathan,
I think you are correct.
I just read on UG-01143 section 3.2.4, "The reference clock network distributes a reference clock source to either the entire left or right side of the FPGA where the transceivers reside. This allows any reference lock pin to drive any transmitter PLL on the same side of the device. Designs using multiple transmitter PLLs which require the same reference clock frequency and are located along the same side of the device, can share the same dedicated reference clock (refclk) pin" .
This is where I get confirmed from official documents that only one reference clock is needed, and can be connected to either GXB banks for x8 PCIe. Thanks for answer!
xytech
Hi Nathan, if you are convenient, could you please kindly help take a look at following question? Thanks again!
https://forums.intel.com/s/question/0D50P00004FCXIxSAP/arial10-powerup-calibration-question
